I want my Rpis to automatically update to the latest kernel pushed out by the Rpi Foundation, so I set up unattended-upgrades
. I assume that's been working - but the kernel version hasn't updated since I installed the OS.
Hitting it with sudo apt update
and then sudo apt full-upgrade
also doesn't get me the latest version of the released kernel. Just says there's no new updates.
I have an Rpi 2B and 3B running "Raspberry Pi OS Lite" and when I SSH in it says the Linux kernel is 5.4.51-v7+ #1333
(version I installed with). It's the default Debian Buster-based OS with minimal packages from https://www.raspberrypi.org/software/operating-systems/ . The current release is on 5.4.83
, per the website.
I can see from the release notes https://downloads.raspberrypi.org/raspios_lite_armhf/release_notes.txt that the release is on 5.4.83
Following these (old) recommendations: Why I can't update kernel version? , How do I upgrade Raspbian? , Stuck with the old kernel
I updated with rpi-update
specifying the closest to 5.4.83
kernel on the site linked https://github.com/Hexxeh/rpi-firmware/commits/master (5.4.81
, 453e49bdd87325369b462b40e809d5f3187df21d).
That Rpi doesn't respond to SSH now, so that's not the way (update: it's now on 5.4.83
through manual reinstallation since it wasn't accessible and manually copying the rpi-update
backups didn't fix it). I'd also like the kernel to update with unattended-upgrades
anyway (and not have to rely on rpi-update
). Also /etc/apt/sources.list.d/raspi.list
has deb http://archive.raspberrypi.org/debian/ buster main
and I think that's right.
I've still got one Rpi ready to get bjorked, what am I missing? This seems like a basic thing that should "just work".
Edit 3
Upgraded the 2nd Rpi on 5.4.51
still to unbootable
. Whoops that's linux for ya
I tried to get around that "not possible" error by the recommendation https://www.raspberrypi.org/forums/viewtopic.php?t=275994#p1672308
sudo nano /var/lib/dpkg/status
[delete libraspberrypi0 libraspberrypi-bin libraspberrypi-dev libraspberrypi-doc raspberrypi-bootloader raspberrypi-kernel entries manually]
sudo dpkg --configure -a
sudo apt update; sudo apt install --reinstall libraspberrypi0 libraspberrypi-{bin,dev,doc} raspberrypi-bootloader raspberrypi-kernel
sudo reboot
Unfortunately though it did install the 5.4.83
kernel with those commands/file editing, the 2nd Rpi did not successfully boot after the reboot command. That's gonna get the same old reinstall, too.
So I'm not sure why 5.4.51
failed to update, but it looks like 5.4.83
will be able to update since my reinstalled Rpi running that responds without error to the --reinstall
command. Will see on next release.
Edit 2
I tried sudo apt install --reinstall raspberrypi-bootloader raspberrypi-kernel
on the reinstalled 5.4.83
Rpi and the command worked (obv nothing changed). But, on the old 5.4.51
Rpi it gives:
Reinstallation of raspberrypi-bootloader is not possible, it cannot be downloaded.
Reinstallation of raspberrypi-kernel is not possible, it cannot be downloaded.
Is this the crux of the problem? How do I circumvent this "not possible"?
Edit, here are the repo's the 5.4.51
Rpi hits:
Hit:1 http://archive.raspberrypi.org/debian buster InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:3 http://archive.raspbian.org/raspbian testing InRelease
The reinstalled Rpi on 5.4.83
has the added repo:
Hit:1 http://packages.microsoft.com/repos/code stable InRelease
The testing branch is for wireguard, it was added with the code:
echo "deb http://archive.raspbian.org/raspbian testing main" | sudo tee --append /etc/apt/sources.list.d/testing.list
printf 'Package: *\nPin: release a=testing\nPin-Priority: 50\n' | sudo tee --append /etc/apt/preferences.d/limit-testing
per the guide for installing wireguard on 5.4.XX
-based Rpi's: https://www.sigmdel.ca/michel/ha/wireguard/wireguard_02_en.html
5.4.51
originally. The one I borked reinstalled just fine to the latest5.4.83
but the 2nd one is still on5.4.51
andapt upgrade
won't get it. I edited the main Q with the repositories it's hitting, maybe it's missing one it needs to update? It's not SD card EOL – user2403531 Feb 01 '21 at 03:06
