I am using a lent 3B+ and now I will buy my own 4B. I have PMS, Pi-Hole, and Samba Server. I don't want to reinstall and re-configure everything again, is there an easy alternative?
One easy way to do this is with the image-utils tool. It copies everything on your SD card, and writes it to a file. You can use your desktop machine (or your RPi) with balena etcher or rufus to write this image file to another SD card.
Note: This procedure assumes that the RPi 3B you've been using is running the Buster version of RPi OS. Buster was released in mid-2019, so it has been around for about 18 months now. The RPi 4B will not run an older version of the OS. Therefore: If the RPi 3B has Stretch, or an even older OS, you'll need to do a fresh install of Buster on the RPi from scratch using these instructions - or similar.
If you're not sure what version of the OS you are running on the RPi 3B, you can check that from the CLI:
$ cat /etc/os-release
You may see this output:
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
If it doesn't say buster, you can quit reading this, and start a fresh install on your 4B.
If your RPi 3B is running Buster, following is a step-by-step process for duplicating the entire OS, including all files, preferences, settings, configurations, etc. This procedure uses the CLI/terminal:
1. Install git on your Raspberry Pi if you don't already have it:
$ sudo apt-get update
$ sudo apt-get upgrade
$ sudo apt-get install git
2. Clone the image-utils repo to create a local copy on your Raspberry Pi
$ cd
$ git clone https://github.com/seamusdemora/RonR-RPi-image-utils
This will create a new folder in your home directory: RonR-RPi-image-utils
3. Mark all of the scripts executable:
$ chmod 755 ~/RonR-RPi-image-utils/image-*
4. Verify that everything is in place:
$ ls -l ~/RonR-RPi-image-utils
-rwxr-xr-x 1 pi pi 12773 Aug 14 21:54 image-backup
-rwxr-xr-x 1 pi pi 1534 Apr 23 2020 image-check
-rwxr-xr-x 1 pi pi 2772 Apr 23 2020 image-compare
-rwxr-xr-x 1 pi pi 2685 Apr 28 2020 image-info
-rwxr-xr-x 1 pi pi 1667 Apr 23 2020 image-mount
-rwxr-xr-x 1 pi pi 5640 May 4 2020 image-set-partuuid
-rwxr-xr-x 1 pi pi 4148 Aug 11 20:11 image-shrink
You will also see README file... Check that all 7 files listed above are present, and have the permissions you see above (-rwxr-xr-x).
5. Select an external ext4 drive as the image file destination
Since the image file may be large, it must be written to an external drive; specifically an external drive under /mnt or /media. Verify that you have a suitable drive mounted in one of those locations - if not, you must mount it. In this case, the drive at /mnt/Passport2TB will be used
$ ls -l /mnt
total ...
drwxr-xr-x 6 pi pi 4096 Jul 11 11:17 Passport2TB
$ lsblk --fs
NAME FSTYPE LABEL UUID FSAVAIL FSUSE% MOUNTPOINT
sda
└─sda1 ext4 PASSPORT2TB 86645948-d127-4991-888c-a466b7722f05 1.5T 10% /mnt/Passport2TB
mmcblk0
├─mmcblk0p1 vfat 6969-16D1 200.3M 22% /boot
└─mmcblk0p2 ext4 f6ea6ef9-68be-479d-b447-5f76391cc02f 26G 6% /
6. Create your "backup" image file:
NOTES:
- In the following "dialog", the user (your) inputs are enclosed in braces {}
- In response to the prompt, "
Image file to create?", use the full path- In response to the prompt, "
Image file to create?", use an .img file extension
$ $ sudo RonR-RPi-image-utils/image-backup
Image file to create? {/mnt/Passport2TB/RPi4Bimage_20201202.img}
Initial image file ROOT filesystem size (MB) [2216]? {↵}
Added space for incremental updates after shrinking (MB) [0]? {222↵}
Create /mnt/Passport2TB/RPi4Bimage_20201202 (y/n)? {y}
Starting full backup (for incremental backups, run: RonR-RPi-image-utils/image-backup /mnt/Passport2TB/RPi4Bimage_20201202)
It will take some time to create the image file... but eventually (a few minutes)
e2fsck 1.44.5 (15-Dec-2018)
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/loop0p2: 55598/157760 files (0.6% non-contiguous), 495225/623872 blocks
Recap
You should now have a file that contains an image of the "root and boot" partitions of your RPi OS from the SD card on your RPi 3B. You may now transfer this file to your Windows/Mac/Linux desktop, where you can use rufus or etcher (for example) to write (not copy) this image file to an SD card. Insert this SD card into your RPi 4B, and it should boot with no problems.
That should do it. Let us know if you have questions.
- 21,900
- 3
- 33
- 70
Just copy the SD card. Everything is stored on the card.
- 71,024
- 5
- 73
- 106
One thing to be careful of is if you have set a static IP address up for Pi-Hole on your router and not your Pi as the change over will give a new MAC address and therefore a new IP address unless you have set either the MAC or IP up on that card. – Dec 02 '20 at 20:00
Provided the Pi has an up-to-date Raspberry Pi OS it will work on ALL Pi models.
It is POSSIBLE to configure Raspberry Pi OS in such a way that it operates differently on different models, but not by default. If you examine /boot/config.txt you would see these.
Setting a static IP Address is one of potential problems.
- 59,890
- 31
- 101
- 209
1I am using LAN cable and I haven't set any static IP anywhere to the best of my knowledge. – Abbas Merchant Dec 03 '20 at 14:02
Since I had to do the same, here is how I managed.
First off: While Raspberry Pi OS is now compatible with all versions, it looks like the older installs created the boot partition too small, thus relevant firmware files for the Pi 4(B) cannot be put where they need to be. Thus increasing the boot partition is a must. If you are lucky enough to already have had a boot partition of at least 100MB, you may just upgrade and use the SD as is. However most likely you went with the old standard and should have some 50MB for boot.
Prerequirements: A linux/UNIX OS on a PC (may be a live version, too), SD-card adapter to said PC and either enough space for the image (dangerous) or preferably a second SD-card.
Since you run SAMBA and seem to have quite a bit of modifications, I assume you are advanced regarding CLI, the dangers of dd(!!!), and e.g. device files.
1. Update OS
Ensure that you are running the latest version of Raspberry Pi OS, on the Pi run:
apt update && apt upgrade
Now cat /etc/issue should get you Rasbpian 10 (= buster).
2. Create image of existing root partition
Take out the SD-Card and connect it to your PC. I'll assume the device is /dev/sdX
2a. Preparations for speeding up dd
Mount the root partion (/dev/sdX2) of your RPi OS and create a dummy file anywhere. Write zeros to it.
dd if=/dev/zero of=<path/to/dummy/file/on/SD/card/zerofiller.dummy>
The reasoning behind this is that dd copies empty areas of a partition, too, however NUL-bytes can be skipped while creating the image. Of course this means one writing for the whole SD Card, thus don't do that too often (may reduce lifetime). The boot-partition is rather small, zero-filling can be skipped there.
2b. Creating an image
In this case I'll create an image of the boot and root partitions and save it on the PC's hard drive. If you happen to have two SD-Card adapters and the new SD card is larger, you may directly copy the image to the new SD-Card and save some time. (see point 4)
dd if=/dev/sdX1 of=/home/joe/RPi_boot.image bs=4M
dd if=/dev/sdX2 of=/home/joe/RPi_root.image bs=4M conv=sparse
Now conv=sparse is for skipping the NUL bytes from 2a. The image is now of the original size of the partition. In order to shrink it to the size of the actual data only, use this:
#this check is a prerequirement before running the resizing
e2fsck -f RPi_root.image
resize2fs -M RPi_root.image
The skrinking is necessary if you want to either reuse the old SD or have a new one of the same size as the old one. Why? The new boot partition is sligtly larger, this the old root won't fit in the leftover space. For a new, larger SD, this is not needed. dd performance should not vary, as the empty space was filled with zeros. By the way: the new boot partition size goes from ~50MB to ~250MB, thus roughly 200MB of free space in the original root are assumed.
3. Preparing the new SD
Now here is the problem: if you are lucky to have a new SD, use this, if you must reuse the old one, this is where the danger comes in, as you need to format it - so make sure the images from 2b are good!
I'll assume the new SC-Card is on /dev/sdY
3a. Download RPi OS image
The light version will do. Unzip the image and copy it to the (new) SD Card.
dd if=/home/joe/2020-08-20-raspios-buster-armhf-lite.img of=/dev/sdY bs=4M
(At this point you may check if the Pi properly boots with this. Then back to the PC with the SD-Card).
3b. Copy old image to new root
Now is the time to put the old image on the new SD. Note that it is not necessary to copy the boot partition unless you made deeper changes there, the root will suffice. The above image of boot image is just for backup and restoration reasons.
dd if=/home/joe/RPi_root.image of=/dev/sdY2 bs=4M conv=sparse
Since the image is of the exact size of the data, the partition will now only be of smaller size, so we need to increase it to fill all of the free space on the SD. Similarly to 2b, but resize2fs without options will just increase to the maximum:
e2fsck -f /dev/sdY2
resize2fs /dev/sdY2
3c. Finalizing
Last but not least your partition IDs will most likely have changed, thus /etc/fstab needs an update. To get the relevant IDs use blkid. Example output for my RPi OS SD-partitions:
blkid
/dev/sda1: LABEL_FATBOOT="boot" LABEL="boot" UUID="3725-1C05" TYPE="vfat" PARTUUID="38de8cd2-01"
/dev/sda2: LABEL="rootfs" UUID="fd695ef5-f047-44bd-b159-2a78c53af20a" TYPE="ext4" PARTUUID="38de8cd2-02"
Mount the root partition, open /etc/fstab, and update the PARTUUIDs. Example file:
proc /proc proc defaults 0 0
PARTUUID=38de8cd2-01 /boot vfat defaults 0 2
PARTUUID=38de8cd2-02 / ext4 defaults,noatime 0 1
Just to be sure run sync to finalize the writes, unmount and you should be ready to boot the RPi 4B with all the old stuff in place and the whole system as you had it before.
4. Alternative: direct copy to a new, larger SD Card
In case your new SD is larger than the old one and you may connect both at the same time, you can skip writing an image to the PC's hard drive.
With the old SD, do steps 1 and 2a.
Prepare the new SD with a fresh image as in 3a
Alter step 3b to directly copy the
rootpartition from old to new:dd if=/dev/sdX1 of=/dev/sdY1 conv=sparce bs=4MProceed with resizing, finalizing and updating
fstabas above.
- 109
- 5
Thus increasing the boot partition is a must.. I don't think this is correct - have you actually tried this? Firmware for the 4B is stored in EEPROM - not in/boot. And when it is downloaded during anapt updateit is stored in/lib/firmware/raspberrypi/bootloader/. It is not stored in thebootpartition on a 4B. Please read The Organization's documentation of the process; you may wish to revise your answer accordingly. – Seamus Dec 03 '20 at 22:38 -
@Seamus Yes, I did and it fixed my problem regarding moving my system from a 3B+ to a 4B - the whole config could be restored as is on the new hardware. The official documentation claims
elf-files to be firmware (incl. specific Pi4elf's), the boot section of the official, fresh image is already larger (even with light version). I can only imagine removing somekernel?.imgto save space as alternative, but have not tried and it would create the same space-limitation problems during the next upgrade, so no good fix. – FelixJN Dec 04 '20 at 08:37 -
To clarify the above: contents of
/bootin the current officiall image (2020-08-20) are larger than 50MB – FelixJN Dec 04 '20 at 08:44
bootpartitions were of ~50MB and thus firmware for the 4B is not installed during upgrades (no space left). This was an issue when I tried to move from 3B+ to 4B in my case. Does the util allow writing to a different partition setup so that one may increasebootand install 4B firmware? – FelixJN Dec 03 '20 at 11:15/boot. And when it is downloaded during anapt updateit is stored in/lib/firmware/raspberrypi/bootloader/. It is never stored in thebootpartition on a 4B - never. The Organization's documentation includes a rather arcane description of the process. You may also find more useful info in this answer – Seamus Dec 03 '20 at 22:32/boot; their size is in sum less than 10MB, but made the 50MB too small. Maybe deleting older kernel images might help, but the space limit is a matter. See also this thread regarding problems with a too small boot section during upgrade. I seem to have been luck to have "only" missed Pi4 boot files and not bricked my Pi3 – FelixJN Dec 04 '20 at 08:22/bootas the RPi 3B, 1BP (and others). I have all 3 of these systems - they all have a/bootpartition of ~ 200MB, and all report that approx 20% of that partition is in use (perlsblk --fs). In fact, theapt upgradeprocess stores all of the.elffiles unique to the 4B in the 3B and the 1BP. In other words - the/bootpartition on your 3B already has the files needed by the 4B! – Seamus Dec 04 '20 at 19:37/boot. *However, your alarm over a 50MB boot partition still seems "misplaced*". Granted - there were 50MB boot partitions on older versions (prior toBuster), but RPi 4B will not run those older OS. – Seamus Dec 04 '20 at 20:25/bootand I wondered if he faced the same problem as I did before. Obviously that is not a problem for his case. Others might profit. – FelixJN Dec 04 '20 at 22:14/bootpartition on a Buster system, but that's not important. I think we've both learned something (I know I have), and that's the point of this. Thanks for challenging my bogus assertion re the firmware :) – Seamus Dec 04 '20 at 23:11
