I've installed Volumio v2.8.61 on a new mSD card. After making all setting, I checked the /boot folder - it's almost full (95%)! Therefore it's not possible to maka an upgrade. What's wrong?
The outputs below.
Many thanks!
Thomas
volumio@volumio:/boot$ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/mmcblk0p2 2.2G 811M 1.3G 39% /imgpart
/dev/loop0 347M 347M 0 100% /static
overlay 13G 383M 12G 4% /
devtmpfs 471M 0 471M 0% /dev
tmpfs 485M 1.6M 484M 1% /dev/shm
tmpfs 485M 4.7M 481M 1% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 485M 0 485M 0% /sys/fs/cgroup
tmpfs 485M 28K 485M 1% /tmp
tmpfs 485M 0 485M 0% /var/spool/cups
tmpfs 20M 208K 20M 2% /var/log
tmpfs 485M 0 485M 0% /var/spool/cups/tmp
/dev/mmcblk0p1 61M 57M 3.4M 95% /boot
STORAGE:/tank/Music/POP 6.7T 4.3T 2.5T 64% /mnt/NAS/1-POP
STORAGE:/tank/Music/CLASSICAL 6.7T 4.3T 2.5T 64% /mnt/NAS/3-CLASSICAL
STORAGE:/tank/Music/JAZZ 6.7T 4.3T 2.5T 64% /mnt/NAS/2-JAZZ
tmpfs 97M 0 97M 0% /run/user/1000
> volumio@volumio:/boot$ ls -la total 57563 drwxrwxrwx 4 root root
> 3072 Jan 1 1970 . drwxrwxrwx 1 root root 4096 Jan 1 1970 ..
> -rw-rw-rw- 1 root root 41 Dec 22 14:46 .firmware_revision
> -rw-rw-rw- 1 root root 41 Dec 22 14:46 .firmware_revision_kernel drwxrwxrwx 2 root root 512 Jan 6 10:13 System Volume Information
> -rw-rw-rw- 1 root root 24246 Dec 22 14:46 bcm2708-rpi-b-plus.dtb
> -rw-rw-rw- 1 root root 23983 Dec 22 14:46 bcm2708-rpi-b.dtb
> -rw-rw-rw- 1 root root 23764 Dec 22 14:46 bcm2708-rpi-cm.dtb
> -rw-rw-rw- 1 root root 24424 Dec 22 14:46 bcm2708-rpi-zero-w.dtb
> -rw-rw-rw- 1 root root 23688 Dec 22 14:46 bcm2708-rpi-zero.dtb
> -rw-rw-rw- 1 root root 25310 Dec 22 14:46 bcm2709-rpi-2-b.dtb
> -rw-rw-rw- 1 root root 25459 Dec 22 14:46 bcm2710-rpi-2-b.dtb
> -rw-rw-rw- 1 root root 27119 Dec 22 14:46 bcm2710-rpi-3-b-plus.dtb
> -rw-rw-rw- 1 root root 26500 Dec 22 14:46 bcm2710-rpi-3-b.dtb
> -rw-rw-rw- 1 root root 25314 Dec 22 14:46 bcm2710-rpi-cm3.dtb
> -rw-rw-rw- 1 root root 41108 Dec 22 14:46 bcm2711-rpi-4-b.dtb
> -rw-rw-rw- 1 root root 52360 Dec 22 14:46 bootcode.bin
> -rw-rw-rw- 1 root root 399 Dec 22 14:47 cmdline.txt
> -rw-rw-rw- 1 root root 169 Dec 22 14:47 config.txt
> -rw-rw-rw- 1 root root 7272 Dec 22 14:46 fixup.dat
> -rw-rw-rw- 1 root root 5398 Dec 22 14:46 fixup4.dat
> -rw-rw-rw- 1 root root 3151 Dec 22 14:46 fixup4cd.dat
> -rw-rw-rw- 1 root root 8417 Dec 22 14:46 fixup4db.dat
> -rw-rw-rw- 1 root root 8413 Dec 22 14:46 fixup4x.dat
> -rw-rw-rw- 1 root root 3151 Dec 22 14:46 fixup_cd.dat
> -rw-rw-rw- 1 root root 10261 Dec 22 14:46 fixup_db.dat
> -rw-rw-rw- 1 root root 10263 Dec 22 14:46 fixup_x.dat
> -rw-rw-rw- 1 root root 5158072 Dec 22 14:46 kernel.img
> -rw-rw-rw- 1 root root 5466824 Dec 22 14:46 kernel7.img
> -rw-rw-rw- 1 root root 5801056 Dec 22 14:46 kernel7l.img drwxrwxrwx 2 root root 16384 Aug 5 17:46 overlays
> -rw-rw-rw- 1 root root 2976416 Dec 22 14:46 start.elf
> -rw-rw-rw- 1 root root 2252288 Dec 22 14:46 start4.elf
> -rw-rw-rw- 1 root root 799836 Dec 22 14:46 start4cd.elf
> -rw-rw-rw- 1 root root 3743076 Dec 22 14:46 start4db.elf
> -rw-rw-rw- 1 root root 3011076 Dec 22 14:46 start4x.elf
> -rw-rw-rw- 1 root root 799836 Dec 22 14:46 start_cd.elf
> -rw-rw-rw- 1 root root 4814916 Dec 22 14:46 start_db.elf
> -rw-rw-rw- 1 root root 3734692 Dec 22 14:46 start_x.elf
> -rw-rw-rw- 1 root root 90 Dec 22 13:40 userconfig.txt
> -rw-rw-rw- 1 root root 19946350 Dec 22 14:53 volumio.initrd
/bootwithout data loss. – FelixJN Jan 06 '21 at 19:24
