I have a connected a Raspberry Pi Zero (1.3, no W, running Raspbian 10 (buster) lite) as an I2C slave (clock:GPIO18,data:GPIO19) to a Raspberry Pi 3b (running Ubuntu 20.04.1) as an I2C master(clock:GPIO3,data:GPIO2).
- The wiring is Dupont style connectors of approximately 20cm length connected directly between the GPIO headers.
- The only configuration done is to uncomment the
dtparam=i2c_arm=onin the config.txt of the boot/firmware directory on both the raspberry pi 3B and the Zero. - Packages installed are
python3-pigpioand dependencies on the Pi Zero, andpython3-smbuson the Pi 3b.
There is barely any load on either of the nodes:
samveen@pi3:~$ cat /proc/loadavg
0.00 0.00 0.00 1/171 2538
pi@pi0:~$ cat /proc/loadavg
0.20 0.21 0.18 1/81 720
The connection works when tested with the python3-pigpio I2C slave example and a simple python3-smbus script on the master:
#!/usr/bin/env python3
import smbus
import time
DEVICE_BUS = 1
DEVICE_ADDR = 0x09
bus = smbus.SMBus(DEVICE_BUS)
def sendData(slaveAddress,reg,data):
intsOfData = list(map(ord, data))
bus.write_i2c_block_data(DEVICE_ADDR, reg, intsOfData)
message=""
for c in '0123456789abcdef01234567890abcdef0':
message+=c
print("sending {} bytes".format(len(message)))
sendData(DEVICE_ADDR,0x00,message)
time.sleep(2)
Observations:
- The communication is rock solid up while message length is 16 bytes or less.
- Messages longer than 16 bytes do not deliver reliably: the first 16 bytes get delivered fine, but anything past that is non-deterministically received. Out of the 32 messages sent per run of the above script, the best run had only 3 of the 16 longer-that-16-byte messages received correctly.
Question:
- What can I do to improve the I2C communication between the 2, so that I have completely reliable messaging?
References:
- Raspberry as an I2C SLAVE
- i2c-tools and python3-smbus source which wasn't as helpful as expected.
- Random yet useful search result for python3-smbus documentation, as the package
helpinpythondoesn't explain the meaning of the parametercom... - Kernel I2C documentation which was required to make sense of the i2c-tools sources.
pigpioquestions :D). also the possibility of how I can extend the 16 byte buffer into a 32 byte buffer? As in which portion of the sources, ligpigpio or pigpiod or the python lib code? I am not in control of message length (final communication endpoint on the master end will not be my code). – Samveen Oct 18 '20 at 12:15
