I'm trying to connect multiple sensors to the Power and I2C pins of the GPIO header of a Pi 3B, but I can't find an easy way to do it using the standard plug-in jumper cables that are often used for prototyping.
All I could find was these splitters on Amazon, which would allow me to connect two devices, assuming the pins are the right size (as it happens the pins I need are next to each other):
splitter product
I was hoping for something that could be "stacked", like these banana plug jumpers but obviously smaller:
stacking banana jumpers
It seems to me that I2C is very convenient for connecting multiple sensors, since they can all share the same pins - but it would be a shame if I can't get this sharing to occur without soldering or introducing a bulky solderless breadboard...
Metamorphic
  • 283
    There are two to eight ways compact, space saving latch lever splitters. I also DIY Tamiya signal/power one male to multiple female connectors. For more than 8 connectors, I usually solder proto board 5 connect strip boards for I2C or SPI signal splitters: https://imgur.com/gallery/b9Z8ygK. – tlfong01 Dec 13 '19 at 07:09
  • Two more related answers your may find useful. I usually go to Pimoroni for DIY ideas: (1) https://raspberrypi.stackexchange.com/questions/104705/how-to-tap-tee-fork-the-rpi-gpio-pins-covered-blocked-by-a-hat-phat-bo (2) https://raspberrypi.stackexchange.com/questions/104307/how-to-physically-wire-two-i2c-sensors-scl-sda-signals-to-a-single-i2c-bus. You may also find in one of my answers about the I2C wiring related, annoying, GROUNDING problem and how to avoid the trouble. – tlfong01 Dec 13 '19 at 07:39
  • This is the thing I refer above: PCT-213 222-413 Spring Lever Push Fit Cable 3 wire Wiring Connector Universal Compact Terminal Block https://www.dhgate.com/product/-100-pieces-lot-wago-222-413-pct-213-type/400202993.html – tlfong01 Dec 13 '19 at 07:48
  • @tlfong01 Thanks for the link to the other question. I decided to post my answer there: https://raspberrypi.stackexchange.com/a/106299/91313 – Metamorphic Dec 13 '19 at 22:15
  • You are welcome. Nice to read your answer later. Cheers. – tlfong01 Dec 14 '19 at 00:44
Use a breadboard like the rest of us. They come in many sizes; the smaller breadboards will take up less space, and you are less likely to damage the Pi.
NOTE to use I²C you NEED 3 connections at least and most I²C devices also need a 4th connection for power.
See https://raspberrypi.stackexchange.com/a/79884/8697 but there are hundreds of tutorials.
