does anyone know details about connecting a GPS module to raspberry pi, i don't want to waste one USB port by using, GPSmodules with USB connection....
Asked
Active
Viewed 3,864 times
1Waste ???? You could always use Self-powered USB Hub and expand USB ports. USB GPS module is indeed the best choice. – Sufiyan Ghori Oct 23 '13 at 07:34
I moved my answer to http://raspberrypi.stackexchange.com/questions/547/how-do-i-attach-a-gps-receiver/10268#10268 as it is better suited there. Since this question will most likely be closed, removed, shredded and forgot about. – Piotr Kula Oct 23 '13 at 09:52
It's unclear how what you're asking is different from this question. If you'd like to reopen the question, please edit it to clarify what you're asking. – ramblinjan Oct 23 '13 at 15:38
1A suggestion--if you're asking if there's a way to use a GPS module not hooked up through a USB port, change the question to reflect that. – ramblinjan Oct 23 '13 at 15:39
You should buy a GPS module that have serial (UART) interface. Then you can connect the GPS module to Raspberry Pi through GPIO pins. There is a blog about 3DR GPS module at http://diydrones.com/profiles/blogs/how-to-connect-3dr-gps-ublox-to-raspberry-pi
gurcanozturk
- 3,748
- 19
- 17
1-1 The answer is in the link I provided in the comment. You should have voted to close this answer as its duplicate – Piotr Kula Oct 23 '13 at 14:55
