How to read ADC results from ADS1256?
Short Answer
Getting to know SPI
As pointed out by @Sim Son, you need to know basic SPI and have some
practical hardware/software experience, before you can understand how
SPI ADS1256 programming.
Getting to know ADC
Then you need to know basics of ADC, like what is the meaning of
single end and differential end channels, gain factors etc,
Getting to know ADS1256
Then you need to read the data sheet, to get a rough idea of the
functions of the pinout, eg, AN-~AN7, Reset, DataReady (Note 1), Beside the SPI
pins (CLK, MOSI, MISO, CS), and the functions of the 11 registers.
Getting to know the WaveShare ADS1256 Demo Program
Then you can now study the program and get a rough idea of what the
program is doing its job by 3 big steps:
Define Gain Channels, Data Rates, Register Addresses, ADC Commands
Define ADS1256 Class with methods init, reset, writeCommand, writeReg, ReadData
Define ADC1256 methods readChipId, config, setSingleEndChannel, setDiffChannel, setScanMode, init, waitReady, readData,
getOneChannelValue, getAllChannelValues, ...
Note 1 - As pointed out by @Roger Jones, the DataReay pin is important if you wish to get the highest sample rate. The following picture show how to roughly calculate the maximum data rate for a particular SPI frequency.
Now I am connecting Rpi to the ADS1256 Module
ADS1256 Test Rig
Long Answer
(1) ADS1256 Datasheet - TI
(2) [ADS1256] Measuring Single-Ended 0- to 5-V Signals with Differential Delta-Sigma ADCs Application Report - TI 2015may
(3) [ADS1256] How delta-sigma ADCs work, Part 1 - TI
(4) How can ADS1256 Read Negative Values?
(5) How can ADS1256 Read Full Scale Values?
(6) ADS1256 Python Libraries
(7) C library for Broadcom BCM 2835 [GPIO] as used in Raspberry Pi [v1.59 2012 26 pin Rpi 2]
(8) WaveShare ADS1250 ADC Module Tutorial
(9) WaveShare ADS1250 ADC Module Schematic
(10) Waveshare/High-Precision-AD-DA-Board Python 3 Demo Program
(11) AliExpress ADS1256 24 Bit ADC Modules
(12) AliExpress ADS1256IDB ADC Module - US$30
Appendices
Appendix A - WaveShare ADS1256 ADC Module Picture
Appendix B - WaveShare ADS1256 ADC Module Schematic
Appendix C - ADS1256 Characteristics
Appendix D - ADS1256 Overview
Appendix E - ADS1256 Connection Diagram
Appendix F - Rpi3B+ ADS1256 Wiring V0.2
Circuit URL
Appendix G - ADS1256 Register Map
Appendix H - Commands
Appendix I - One shot mode ADC
For one short mode of standby-wakeUp-readData, the wake up delay is only 33.3 uS.
Appendix J - Write Register and Read Register
Appendix K - Status Register 0x00
Appendix L - SPI Loopback test (before testing ADS1256)
Now I am doing a SPI loopback test as a preparation to read and write ADS1256 ADC registers.
# spi_loopback_50_2019jun0901 tlfong01 2019jun09hkt2153 ***
# Rpi3B+ stretch 2019apr08, python 3.5.3
# Test - loopBackTest - SPI port send and receive one byte/two bytes/three bytes.
# Function - Send 1/2/3 bytes MOSI and read back from MISO.
# Setup - Connet MOSI pin to MISO pin to form a loop.
# Setting up for 2 SPI channels
# /boot/config.txt dtoverlay setting
# dtparam=i2c_arm=on
# dtparam=spi=on
# dtoverlay=spi1-3cs
# $ ls -l /dev/spi* should show the following 5 SPI ports:
# /dev/spidev0.0, /dev/spidev0.1, /dev/spidev1.0, /dev/spidev1.1, /dev/spidev1.2
from time import sleep
import spidev
# *** SPI Channel 0 Config ***
spiPort00 = spidev.SpiDev()
spiPort00.open(0,0)
spiPort00.max_speed_hz = 100000
spiPort01 = spidev.SpiDev()
spiPort01.open(0,1)
spiPort01.max_speed_hz = 100000
# *** SPI Channel 1 Config ***
spiPort10 = spidev.SpiDev()
spiPort10.open(1,0)
spiPort10.max_speed_hz = 100000
spiPort11 = spidev.SpiDev()
spiPort11.open(1,1)
spiPort11.max_speed_hz = 100000
spiPort12 = spidev.SpiDev()
spiPort12.open(1,2)
spiPort12.max_speed_hz = 100000
# *** SPI Send/Receive 1/2/3 Bytes ***
def spiSendRecvOneByte(spiPort, sendByte):
sendByteArray = [sendByte]
recvByteArray = spiPort.xfer(sendByteArray)
return recvByteArray
# *** Loopback 1/2/3 Bytes ***
def loopbackOneByte(spiPort, sendByte):
recvByteArray = spiSendRecvOneByte(spiPort, sendByte)
recvByte = recvByteArray[0]
print('\n Begin loopbackOneByte(),....')
#print('')
print(' sendByte = ', hex(sendByte))
print(' recvByte = ', hex(recvByte))
#print('')
print(' End loopbackOneByte(),....', end = '')
return
# *** Tests to loopback SPI Channel 0 ***
def testLoopbackOneByteSpiPort0():
print('\nBegin loopbackOneByteSpiPort0(),....', end = '')
loopbackOneByte(spiPort00, 0x5b)
print('\nEnd loopbackOneByteSpiPort0(),....', end = '')
return
# *** Tests to loopback SPI Channel 1 ***
def testLoopbackOneByteSpiPort1():
print('\nBegin loopbackOneByteSpiPort1(),....', end = '')
loopbackOneByte(spiPort10, 0x5b)
print('\nEnd loopbackOneByteSpiPort1(),....', end = '')
return
# *** Main Tests ***
# *** Loopback Tests ***
#testLoopbackOneByteSpiPort1()
# *** Sample Output ***
''' Smple output
sendByte = 0x5b
recvByte = 0x5b
''' Smple output
sendByte = 0x5b
recvByte = 0x5b
# *** End ***
Appendix M - SPI Loopback test (1/2/3 bytes)
ADS1256 needs send/receive two and three bytes. So I have also tested the 1/2/3 bytes loopback version.
# spi_loopback_123_v70_2019jun0901 tlfong01 2019jun09hkt2302 ***
import spidev
spiPort00.open(0,0)
# *** Spi port functions ***
def setSpiPortSpeed(spiPortNum, speedName):
spiPortList[spiPortNum].max_speed_hz = speedDict[speedName]
return
def closeSpiPortAll():
for i in spiPortList:
i.close()
return
def spiSendRecvTwoBytes(spiPort, sendByte1, sendByte2):
sendByteArray = [sendByte1, sendByte2]
def spiSendRecvThreeBytes(spiPort, sendByte1, sendByte2, sendByte3):
sendByteArray = [sendByte1, sendByte2, sendByte3]
print('\n Begin loopbackOneByte(),...')
#print('')
#print('')
print(' End loopbackOneByte().', end = '')
return
def loopbackTwoBytes(spiPort, sendByte1, sendByte2):
recvByteArray = spiSendRecvTwoBytes(spiPort, sendByte1, sendByte1)
recvByte0 = recvByteArray[0]
recvByte1 = recvByteArray[1]
print('\n Begin loopbackThreeBytes(),...')
#print('')
print(' sendBytes = ', hex(sendByte1), hex(sendByte2))
print(' recvBytes = ', hex(recvByte1), hex(sendByte2))
#print('')
print(' End loopbackTwoBytes().', end = '')
return
def loopbackThreeBytes(spiPort, sendByte1, sendByte2, sendByte3):
recvByteArray = spiSendRecvThreeBytes(spiPort, sendByte1, sendByte1, sendByte3)
recvByte2 = recvByteArray[2]
#print('')
print(' sendBytes = ', hex(sendByte1), hex(sendByte2), hex(sendByte3))
print(' recvBytes = ', hex(recvByte1), hex(sendByte2), hex(sendByte3))
#print('')
print(' End loopbackThreeBytes().', end = '')
return
# *** Test Loopback 1/2/3 bytes ***
print('\nBegin loopbackOneByteSpiPort0(),...', end = '')
print('\nEnd loopbackOneByteSpiPort0().', end = '')
return
def testLoopbackTwoBytesSpiPort0():
print('\nBegin loopbackTwoBytesSpiPort0(),...', end = '')
loopbackTwoBytes(spiPort00, 0x5b, 0x6b)
print('\nEnd loopbackTwoByte0SpiPort0().', end = '')
return
def testLoopbackThreeBytesSpiPort0():
print('\nBegin loopbackThreeBytesSpiPort0(),...', end = '')
loopbackThreeBytes(spiPort00, 0x5b, 0x5c, 0x5d)
print('\nEnd loopbackThreeByteSpisPort0().', end = '')
return
''' Smple output
RESTART: /home/pi/Python Programs/test1203/spi_loopback_test60_2019may3001.py
sendByte = 0x5b
recvByte = 0x5b
sendBytes = 0x5b 0x6b
recvBytes = 0x5b 0x6b
sendBytes = 0x5b 0x5c 0x5d
recvBytes = 0x5b 0x5c 0x5d
# *** End ***
