I have a Smart TV that has ethernet but no wireless capabilities.
I also have a spare RPi1 (Model B) with a wireless USB adapter.
Is there anyway I can use the Pi to connect the TV to my wireless router?
elsmandino
i wished to comment only,
you are asking about bridging the Ethernet adapter to the wifi adapter,
check this, https://www.raspberrypi.org/forums/viewtopic.php?t=132674 it is so user friendly
  • The question was not about to have a bridge and the link you have given is named wrong. That was confusing me first because it isn't possible to bridge a wifi client connection. The author seems not to know what an ethernet bridge is. He described setting up routing. Anyway, that's usable for the problem. – Ingo Jun 07 '19 at 10:08
  • You are now able to comment on every question. So you can make your "answer" a comment and delete it. – Ingo Jun 07 '19 at 10:15
  • i think he want to transfer the traffic from the router to tv and vice versa, the pi is the middle man. – Allaw Hussein Jun 07 '19 at 12:22
You can make the RasPi a router that routes data between the wired and wireless interfaces. But I don't believe that the old RasPi with the limitations of USB for ethernet will be strong enough to ensure an uninterruptible video stream. You can try it. How to setup a router you can look at Can a Raspberry Pi Zero W be turned into an USB WiFi dongle to any USB Host like x86 PC or mini-PC? but only use the section: Use routing.
  • 42,107
  • 85
  • 197
