I am learning how to build a basic robot using a raspberry pi and an L298N h-bridge.
I have followed this tutorial successfully i:e the single DC motor I have connected does work in response to the code. My problem is when I use the code, below, the motor does not work:
import sys
import time
import RPi.GPIO as GPIO
GPIO.setwarnings(False)
Forward = 23
Backward = 24
Enable = 25
GPIO.setmode(GPIO.BCM)
GPIO.setup(Forward, GPIO.OUT)
GPIO.setup(Backward, GPIO.OUT)
GPIO.setup(Enable, GPIO.OUT)
p=GPIO.PWM(Enable, 1000)
p.start(25)
def forward(t):
GPIO.output(Forward, GPIO.HIGH)
GPIO.output(Backward, GPIO.LOW)
print("Moving Forward")
def reverse(t):
GPIO.output(Forward, GPIO.LOW)
GPIO.output(Backward, GPIO.HIGH)
print("Moving Backward")
while(1):
forward(3)
# reverse(3)
GPIO.cleanup()
When I run the script, I get the following error:
Traceback (most recent call last): File "move2.py", line 43, in
forward(3) File "move2.py", line 27, in forward GPIO.output(Forward, GPIO.HIGH)</p>
RuntimeError: Please set pin numbering mode using GPIO.setmode(GPIO.BOARD) or GPIO.setmode(GPIO.BCM)
I had set the pin mode to BCM earlier in the code so I'm not sure why the error is occurring.
I'm not sure what I'm doing wrong.
A little help, please?
