Read 2 thermal couples and 1 pressure gauge using Rpi
Record data and send it to server
A better way to do this?
Answer
I skimmed the datasheet of your thermal sensor, pressure sensor, and current loop receiver module.  My first impression is that they are all mission critical, industrial equipment.
Electrical characteristics of 3 pieces of equipment
Thermal sensor: 4 thermal conducting wire, 4~20mA current loop
Pressure sensor: power = 5V, signal output = 0.5V to 4.5V
ADC module: INA196/ADS1115 based current/voltage ADC
Rpi to ADC module Interface Summary
Communication protocol: I2C
Programming languages (suggestion): python, C/C++, NodeJs, NodeRed
Advice / Warning to Rpi I2C ADC (INA196/ADS1115) newbies
I am new to building things like this and guess I just got confused.
  So for the pressure sensor I can just ignore one of the cables? Using
  the ground and signal cable. – Max 5
Well, your above comment worries me "a bit".  During last couple of months I have been playing as an electronics/programming hobbyist, the hardware/software related to your project: current loop sensors including INA221, ADC including ADS1115, ...
The current sensor INA219 and voltage ADC 16 bit ADS1115 used in you project has a rather steep learning curve for newbies.  You might like to first read the following posts on using these devices, to get a feeling of how hard it is.  If you indeed found it scary, then I can recommend two simple devices ACS712 (current sensing and ADC combined, saving trouble for newbies) and PCF8591 (ADC, but 8 bit only).  You can use these newbie friendly devices as a warm up exercise, before researching on you more advanced, industrial grade equipment.
Reading Voltage Input on ADC [using ACS712 and INA221]
Raspberry Pi Current & Voltage Sensors [using INA219/INA226, ACS712, ADS1015/ADS1115,  ADS1256/AD7190]
/ to continue, ...
Dual Element Thermocouple probe with Standard Size Connector
Specifications
Two Sensor Readings Allows Two Readings of a Single Point
Continuous Monitor and Control & Built-in Backup
Analog Pressure Sensor
Specification
Typical Supply Voltage: 5VDC
Output Voltage Range: 0.5 – 4.5VDC
3-Channel 4-20 mA Current Loop Receiver 16-Bit ADS1115 I2C Mini Module
Features
3 Channel 4-20 mA Current Loop Receiver
3-Channel Input with 16-Bit Resolution
4-20mA Industrial Sensor Monitoring
INA196 Current Shunt Monitoring
Ideal for Sensor and Instrument Monitoring
ADS1115 16-Bit Analog to Digital Converter
Onboard 16V Voltage Supply (Boosted from 5V)
Ideal for Industrial Automation 4-20mA input
