SSH is disabled by default for security, which is annoying for a headless RPi. The usual trick was to create an empty ssh file in /boot/ which was possible even from Windows, because the boot partition is visible.
Now (I tried with Raspbian Stretch Lite) it doesn't seem to work anymore, and this is confirmed by this comment here:
I tried the headless setup on Raspbian Stretch Desktop from 2018-03-14 and it doesn't seem to be working anymore, was working with previous versions. – JBaczuk Apr 3 '18 at 18:36
and also here:
Does NOT work on November raspbian stretch – decades Jan 25 '18 at 15:18
How to do it today? (I'm looking for a solution working from Windows)
/bootBUT in the first partition on the SD Card. – Milliways May 18 '19 at 23:27Why do you want to do it again?I don't understand your question. This feature (bootpartition'ssshfile to enable SSH) should work no matter the age of the image, and it should work on a freshly installed Raspbian... Also I don't understand the close vote reason... – Basj May 18 '19 at 23:43systemctl status ssh? Please address me with @Ingo, otherwise I won't see your answer. – Ingo May 19 '19 at 00:07This feature should work no matter the age of the image- not really, the "feature" didn't exist in the very first image, it was introduced "as of the November 2016 release" - those numpties in the two "examples" you gave just don't know what they are doing or are using older images – Jaromanda X May 19 '19 at 00:59
