I am trying to set up a small wifi network (offline) using the guide found here. https://www.raspberrypi.org/documentation/configuration/wireless/access-point.md
Below I have given my terminal window to show my process and the problem I am having
pi@raspberrypi:~ $ sudo su root
root@raspberrypi:/home/pi# nano /etc/hostapd.conf
root@raspberrypi:/home/pi# nano /etc/dhcpcd.conf
root@raspberrypi:/home/pi# sudo systemctl restart dhcpcd
root@raspberrypi:/home/pi# nano /etc/dnsmasq.conf.orig
root@raspberrypi:/home/pi# mv /etc/dnsmasq.conf.orig /etc/dnsmasq.conf
root@raspberrypi:/home/pi# systemctl reload dnsmasq
root@raspberrypi:/home/pi# sudo nano /etc/hostapd/hostapd.conf
root@raspberrypi:/home/pi# sudo nano /etc/default/hostapd
root@raspberrypi:/home/pi# systemctl unmask hostapd
syroot@raspberrypi:/home/pi# systemctl enable hostapd
Synchronizing state of hostapd.service with SysV service script with /lib/systemd/systemd-sysv-install.
Executing: /lib/systemd/systemd-sysv-install enable hostapd
systemctl root@raspberrypi:/home/pi# systemctl start hostapd
Job for hostapd.service failed because the control process exited with error code.
See "systemctl status hostapd.service" and "journalctl -xe" for details.
root@raspberrypi:/home/pi# systemctl status hostapd.service
● hostapd.service - Advanced IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator
Loaded: loaded (/lib/systemd/system/hostapd.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Fri 2019-05-17 12:12:37 BST; 1s ago
Process: 3140 ExecStart=/usr/sbin/hostapd -P /run/hostapd.pid -B $DAEMON_OPTS ${DAEMON_CONF} (code=exited, status=1/FAILURE)
May 17 12:12:37 raspberrypi systemd[1]: hostapd.service: Control process exited, code=exited status=1
May 17 12:12:37 raspberrypi systemd[1]: Failed to start Advanced IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator.
May 17 12:12:37 raspberrypi systemd[1]: hostapd.service: Unit entered failed state.
May 17 12:12:37 raspberrypi systemd[1]: hostapd.service: Failed with result 'exit-code'.
I have re-imaged and started again twice! Anyone able to help?
DAEMON_CONF="/etc/hostapd/hostapd.conf"
– GigaJoules May 20 '19 at 08:53
