I've got 4 LEDs, a buzzer and a button. There's an add_event_detect to switch the LEDs and buzzer on and off. The callback methods works find when the outputs are just on continuously until another press turns them off. But I want them to sleep for 0.3 seconds and turn on again.
This works kind of with the Keypad. You have to press key 2 quite hard but it works. I can't figure out how to get out of the loop in the btnState function.
A button press turns them on but they stay on.
Wiring
button = Gpio and ground. leds = gpio and ground buzzer = 5v, NPN 8050 transistor to gpio and ground
Code
import RPi.GPIO as GPIO
import time
import Keypad
Leds = [37, 35, 33, 31]
buzz = 13
button = 29
ROWS = 4 # number of rows of the Keypad
COLS = 4 #number of columns of the Keypad
keys = ['1','2','3','A', #key code
'4','5','6','B',
'7','8','9','C',
'*','0','#','D' ]
rowsPins = [12, 22, 24, 26] #connect to the
row pinouts of the keypad
colsPins = [40, 38, 36, 32] #connect to the
column pinouts of the keypad
btnState = 1
alarm_end = time.time() + 60 * 3 # alarm_ends
after 3 mintues
def setup():
GPIO.setmode(GPIO.BOARD)
GPIO.setup(Leds, GPIO.OUT)
GPIO.setup(buzz, GPIO.OUT)
GPIO.setup(button, GPIO.IN,
pull_up_down=GPIO.PUD_UP)
GPIO.setwarnings(False)
def swState(ev=None):
global btnState
if btnState == 1:
btnState = 0
GPIO.output(Leds, btnState)
GPIO.output(buzz, btnState)
while (time.time() < alarm_end or btnState == 0):
print ('Sound the Alarm!!...')
GPIO.output(Leds, True)
GPIO.output(buzz, True)
time.sleep(0.3)
GPIO.output(Leds, False)
GPIO.output(buzz, False)
time.sleep(0.3)
else:
btnState = 1
alarmOff()
def keyPadInput():
keypad = Keypad.Keypad(keys,rowsPins,colsPins,ROWS,COLS)
key = keypad.getKey()
if key == '1':
while (key != '2'):
time.sleep(0.3)
time.sleep(0.3)
if (key == '2'):
alarmOff()
elif key == '2':
alarmOff()
def alarmOff():
print ('Turning off system...')
def main():
setup()
print ("Program is starting ... ")
try:
loop()
except KeyboardInterrupt: #When 'Ctrl+C' is
pressed, exit the program.
destroy()
def loop():
GPIO.add_event_detect(button, GPIO.FALLING,
callback=swState, bouncetime=200) # wait for
falling
while True:
keyPadInput()
def destroy():
GPIO.cleanup()
if __name__ == '__main__': #Program start from
here
main()
TIA!
while (time.time() < alarm_end or btnState == 0):line be usingandinstead? i.e. blink the light whilst the alarm's not expired ANDbtnStatehasn't changed. Personally I'd also wrap the two conditions in parethases to visually separate them:while ( ( time.time() < alarm_end ) and ( btnState == 0 ) ):– Roger Jones May 08 '19 at 11:46event_detectinterrupt to toggle thebtnStatevariable but I'm not sure you can have two concurrent interrupts on the same pin? When you first press the button the event triggers and you enter your loop but the second press can't trigger the second event until you exit the loop for the first one sobtnStatenever gets set to1whilst you're in the loop. – Roger Jones May 08 '19 at 11:59
