As I've seen previous projects with the Raspberry Pi being enclosed in stuffed animals and plushies. I've wanted to attempt a project in a similar environment. Will there be a problem with overheating the device when it's enclosed in such a tight location? My Raspberry Pi is already in a Geaux Robot case, so there's that to be considered.
syb0rg
  • 8,188
  • 37
  • 51
BJesso
  • 103
    Similar question asked here: http://raspberrypi.stackexchange.com/q/103/40 – Jivings Sep 24 '13 at 19:29
    And here: http://raspberrypi.stackexchange.com/q/105/40. Short answer; there are no ventilation or cooling requirements. – Jivings Sep 24 '13 at 19:30
  • Therefore it's safe. The outside environment would be 100% room temperature for me, so It probably won't have a chance to overheat; I'll assume that placing metal eyelets for wire holes would count as more than sufficient ventilation. Thanks for the information. @goldilocks thanks :) – BJesso Sep 25 '13 at 04:38
The RPi is unlikely to be a problem. However if you insulate it well enough it will of course overheat eventually.
There will be a temperature gradient from the RPi to the out of the outside of you r Plushie.
John La Rooy
  • 11,947
  • 47
  • 75
This is a similar question to: Environmental Tolerance which has an answer regarding the temperature tolerance.
Chenmunka
  • 625
  • 27
