i have set up hostapd and dnsmasq and ran into some issues. at first the issue was that hostapd didn't recognized the driver. after i deleted that line it did start up. then dnsmasq told me that there was an invalid option in the /etc/dnsmasq.conf which was the "listen-address" option. after deleting that line dnsmasq started up aswell and both services are running. but the problem i have now is that i don't get any signal to my devices. it should normally show the ssid "WiPi-Repeater" but i don't get any signal. i am using:
- Raspberry Pi 3 Model B
- TP-Link Archer T2U wifi dongle
- 2019-04-08-raspbian-stretch-full image.
I hope you guys can help me because i haven't found anything according to my problem yet.
Here is the hostapd.conf:
interface=wlan1
hw_mode=g
channel=6
ieee80211n=1
wmm_enabled=1
ht_capab=[HT40][SHORT-GI-20][DSSS_CCK-40]
macaddr_acl=0
ignore_broadcast_ssid=0
auth_algs=1
wpa=2
wpa_key_mgmt=WPA-PSK
rsn_pairwise=CCMP
ssid=WiPi-Repeater
wpa_passphrase=mypassword
and here the dnsmasq.conf:
interface=wlan1
bind-interfaces
server=8.8.8.8
domain-needed
bogus-priv
dhcp-range=192.168.178.50,192.168.178.150,12h
if i use sudo systemctl is-active dnsmasq
and sudo systemctl is-active hostapd
both are marked as enabled
for the lsusb
command i get:
Bus 001 Device 004: ID 148f:761a Ralink Technology, Corp.
Bus 001 Device 006: ID 1a2c:0e24 China Resource Semico Co., Ltd
Bus 001 Device 005: ID 145f:01de Trust
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
and for lsmod
Module Size Used by
fuse 110592 3
rfcomm 49152 4
bnep 20480 2
hci_uart 36864 1
btbcm 16384 1 hci_uart
serdev 20480 1 hci_uart
bluetooth 368640 29 hci_uart,bnep,btbcm,rfcomm
ecdh_generic 28672 1 bluetooth
ipt_MASQUERADE 16384 1
nf_nat_masquerade_ipv4 16384 1 ipt_MASQUERADE
iptable_nat 16384 1
nf_nat_ipv4 16384 1 iptable_nat
nf_nat 28672 2 nf_nat_masquerade_ipv4,nf_nat_ipv4
nf_conntrack_ipv4 16384 3
nf_defrag_ipv4 16384 1 nf_conntrack_ipv4
xt_conntrack 16384 1
nf_conntrack 126976 6 nf_conntrack_ipv4,ipt_MASQUERADE,nf_nat_masquerade_ipv4,xt_conntrack,nf_nat_ipv4,nf_nat
iptable_filter 16384 1
evdev 24576 8
joydev 20480 0
mt7610u 688128 1
brcmfmac 307200 0
brcmutil 16384 1 brcmfmac
snd_bcm2835 32768 1
snd_pcm 98304 1 snd_bcm2835
cfg80211 573440 2 mt7610u,brcmfmac
snd_timer 32768 1 snd_pcm
rfkill 28672 8 bluetooth,cfg80211
snd 69632 5 snd_timer,snd_bcm2835,snd_pcm
fixed 16384 0
uio_pdrv_genirq 16384 0
uio 20480 1 uio_pdrv_genirq
i2c_dev 16384 0
ip_tables 24576 2 iptable_filter,iptable_nat
x_tables 32768 4 ip_tables,iptable_filter,ipt_MASQUERADE,xt_conntrack
ipv6 425984 28
If you need any more details i can give them but i guess i gave the most details. The only thing like i said is only that i don't get any SSID shown on my devices.
here are the Supported interface mode for Wiphy phy1 aswell:
Supported interface modes:
* IBSS
* managed
* AP
* P2P-client
* P2P-GO
* P2P-device
Update:
I wanted to repeat the connection from onboard to dongle. but since it won't let me do it and it doesn't show me an AP i can't repeat the wifi connection. what i can't do is that i would go from eth0 to wlan0 because i have no wired connection to repaeat since my rpi is going to be in the staircase. if i would find the driver that is installed for the wifi dongle i have i would try to use that for hostapd but yeah... idk where to find it.
iw phy | less
. You will get a buch of information. Scroll to the section starting withWiphy phy1
(not usingphy0
). Within this section select the subsection starting withSupported interface modes:
. Please edit your question and copy and paste the listed modes into it. – Ingo Apr 22 '19 at 19:23supported interface modes
forWiphy phy1
– Mistral Dreamer Apr 23 '19 at 15:22
