Every time I restart my raspberry pi the MAC address changes. Due to this, while connecting remotely I have to hunt for its new IP.
If you decide you want to keep NetworkManager, it looks like this solution might work:
Found a post on the rpi forums. Apparently NetworkManager can randomize your mac to make it harder to people to snoop on traffic.
Here is a blog post on how to turn it off. https://blog.muench-johannes.de/networkmanager-disable-mac-randomization-314 in case it goes down:
To disable the MAC address randomization create the file
/etc/NetworkManager/conf.d/100-disable-wifi-mac-randomization.conf
with the content:
[connection] wifi.mac-address-randomization=1 [device] wifi.scan-rand-mac-address=no
Alternatively, see this other question.
- 337
- 2
- 9
I had the same issue and realised it is because you have two different MAC addresses
- one for the wifi
- one for the ethernet
You can check your MAC address with
ifconfig
in the console. look for the info ether for wlan0 and eth0
- 101
While I agree that the MAC SHOULD not change (except during search, where most manufacturers use a random MAC) you really don't need to know the IP address. (I don't know the IP addresses of my 7 Pi or dozen or so computers on my local network.)
It is simple to connect without knowing IP and also to find the IP address. See https://raspberrypi.stackexchange.com/a/96215/8697
- 59,890
- 31
- 101
- 209
1This is a rather simplistic view. Imagine using DHCP reservations (based on MAC) or connecting through firewalls/routers where this simplistic scenario is simply not possible. – CrackerJack9 May 13 '21 at 01:32
I had the same issue. I found (I don't know how) Network Manger had been installed. Removed it. All now ok.
- 11
raspberrypi.local
as the way to find your Raspberry Pi on the network, check https://bloggerbrothers.com/2017/01/08/name-your-pis-with-mdns-forget-the-ips-with-zeroconf/ – MatsK Apr 11 '19 at 05:00
