I have set the USB device on my Raspberry Pi to default. The file /lib/modprobe.d/aliases.conf:
options snd-pcsp index=-2
options snd-usb-audio index=0
options cx88_alsa index=-2
options snd-atiixp-modem index=-2
options snd-intel8x0m index=-2
options snd-via82xx-modem index=-2
options snd_bcm2835 index=1
That worked out great, till I rebooted raspbian. After the reboot, the USB is not longer default.
But, The device is still displayed as default.
aplay -l:
**** Liste der Hardware-Geräte (PLAYBACK) ****
Karte 0: Device [USB Audio Device], Gerät 0: USB Audio [USB Audio]
Sub-Geräte: 1/1
Sub-Gerät #0: subdevice #0
Karte 1: ALSA [bcm2835 ALSA], Gerät 0: bcm2835 ALSA [bcm2835 ALSA]
Sub-Geräte: 7/7
Sub-Gerät #1: subdevice #1
Sub-Gerät #2: subdevice #2
Sub-Gerät #3: subdevice #3
Sub-Gerät #4: subdevice #4
Sub-Gerät #5: subdevice #5
Sub-Gerät #6: subdevice #6
Karte 1: ALSA [bcm2835 ALSA], Gerät 1: bcm2835 ALSA [bcm2835 IEC958/HDMI]
Sub-Geräte: 1/1
cat /proc/asound/cards:
0 [Device ]: USB-Audio - USB Audio Device
C-Media Electronics Inc. USB Audio Device at usb-3f980000.usb-1.4, full speed
1 [ALSA ]: bcm2835_alsa - bcm2835 ALSA
bcm2835 ALSA
In the raspbian gui in the top right corner at sounds, the USB device is also selected.
But when I play a Youtube video or play music with omxplayer, there is no Sound. When I start the vlc player, bcm2835 is selected. If i switch it to the usb device, then i can hear the sound with the vlc player only. When I open the pavumeter, the bcm2835 is also selected as the device. It used the USB device before.
Raspberry Pi 3 B
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 9.8 (stretch)
Release: 9.8
Codename: stretch
UPDATE:
A workaround is blacklisting the bcm2835 device:
- Add
blacklist snd_bcm2835in/etc/modprobe.d/raspi-blacklist.conf
pavucontrol. – CL. Apr 05 '19 at 13:39pavucontrolshows me which audio device is used for the application and let me hanges this for the application. But how can i set this up for all applications global, that alle applications using the usb device instead ofbcm2835? – micharaze Apr 05 '19 at 13:46
