I'm configuring RPi as a WiFi repeater. Built-in WiFi module works as a main network adapter and configured to receive DHCP address. Second adapter Asus N10 dongle, meant to create a local WiFi network, detected successfully after inserting as wlan1
in addition to built-in wlan0
. Problem is, after reboot interface disappearing from the system (ifconfig does not show wlan1) and I need to re-insert it.
I tried configuring /etc/network/interfaces
auto wlan1
allow-hotplug wlan1
iface wlan1 inet manual
and /etc/dhcpcd.conf
interface wlan1
static ip_address=192.168.4.1/24
nohook wpa_supplicant
No effect, adapter still requires re-inserting
UPDATE
dmesg
output right after boot gives the following messages
[4.348457] usb 1-1.2: r8712u: USB_SPEED_HIGH with 4 endpoints
[4.349986] usb 1-1.2: r8712u: Boot from EFUSE: Autoload OK
[4.605101] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Feb 27 2018 03:15:32 version 7.45.154 (r684107 CY) FWID 01-4fbe0b04
[4.605826] brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 9.10.105 Compiler: 1.29.4 ClmImport: 1.36.3 Creation: 2018-03-09 18:56:28
[4.977617] usb 1-1.2: r8712u: CustomerID = 0x0010
[4.977639] usb 1-1.2: r8712u: MAC Address from efuse = 30:85:a9:6e:5a:d9
[4.977650] usb 1-1.2: r8712u: Loading firmware from "rtlwifi/rtl8712u.bin"
30:85:a9:6e:5a:d9
is Asus N10 MAC address
After I re-insert the adapter, I see new messages in the output
[436.052089] usb 1-1.2: new high-speed USB device number 7 using dwc_otg
[436.184403] usb 1-1.2: New USB device found, idVendor=0b05, idProduct=1786
[436.184419] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[436.184428] usb 1-1.2: Product: ASUS EZ N Network Adapter
[436.184436] usb 1-1.2: Manufacturer: Manufacturer Realtek
[436.184444] usb 1-1.2: SerialNumber: 00e04c000001
[436.187629] r8712u: register rtl8712_netdev_ops to netdev_ops
[436.187653] usb 1-1.2: r8712u: USB_SPEED_HIGH with 4 endpoints
[436.189124] usb 1-1.2: r8712u: Boot from EFUSE: Autoload OK
[436.613105] usb 1-1.2: r8712u: CustomerID = 0x0010
[436.613125] usb 1-1.2: r8712u: MAC Address from efuse = 30:85:a9:6e:5a:d9
[436.613149] usb 1-1.2: r8712u: Loading firmware from "rtlwifi/rtl8712u.bin"
[437.562399] r8712u 1-1.2:1.0 wlan1: 1 RCR=0x153f00e
[437.562936] r8712u 1-1.2:1.0 wlan1: 2 RCR=0x553f00e
[439.682544] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
UPDATE2
Also I receive Under-voltage detected! (0x00050005)
message during every reboot. Maybe it affects hardware initialization, I'm not sure
UPDATE3
ifconfig as requested
eth0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether b8:27:eb:f9:c3:2d txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
RX packets 1554 bytes 185783 (181.4 KiB)
TX packets 1554 bytes 185783 (181.4 KiB)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.0.38 netmask 255.255.252.0 broadcast 192.168.3.255
inet6 fe80::f490:92fc:c558:8541 prefixlen 64 scopeid 0x20<link>
ether b8:27:eb:ac:96:78 txqueuelen 1000 (Ethernet)
RX packets 16671 bytes 16141581 (15.3 MiB)
RX errors 0 dropped 18 overruns 0 frame 0
TX packets 11804 bytes 1416579 (1.3 MiB)
Asus adapter description, which appears after re-inserting
wlan1: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 30:85:a9:6e:5a:d9 txqueuelen 1000 (Ethernet)
dmesg
regarding the adapter before and after you re-insert it - post any relevant dmesg info in the question – Jaromanda X Mar 28 '19 at 12:38ifconfig -a -s
– Jaromanda X Mar 28 '19 at 13:39ifconfig
output is ... but did you doifconfig -a
- I want to see if it's just down for some reason – Jaromanda X Mar 28 '19 at 14:20-a
flag toifconfig
- it's not clear :p – Jaromanda X Mar 28 '19 at 14:36
