I have been following the tutorial on this page on setting up the raspbery pi
https://www.raspberrypi.org/documentation/configuration/camera.md
and when I run sudo vcgencmd get_camera
I get supported=1 detected=1
however when I run raspistill -v -o test.jpg I get:
raspistill Camera App v1.3.11
Time delay 5000, Raw no
Thumbnail enabled Yes, width 64, height 48, quality 35
Link to latest frame enabled no
Full resolution preview No
Capture method : Single capture
Preview Yes, Full screen Yes
Preview window 0,0,1024,768
Opacity 255
Sharpness 0, Contrast 0, Brightness 50
Saturation 0, ISO 0, Video Stabilisation No, Exposure compensation 0
Exposure Mode 'auto', AWB Mode 'auto', Image Effect 'none'
Flicker Avoid Mode 'off'
Metering Mode 'average', Colour Effect Enabled No with U = 128, V = 128
Rotation 0, hflip No, vflip No
ROI x 0.000000, y 0.000000, w 1.000000 h 1.000000
mmal: mmal_vc_component_enable: failed to enable component: ENOSPC
mmal: camera component couldn't be enabled
mmal: main: Failed to create camera component
mmal: Failed to run camera app. Please check for firmware updates
things i have tried: 1. Enabled the camera through a terminal on the PI via "sudo raspi-config" 2. Restarted
Updated the Raspberry PI firmware through a terminal with "sudo rpi-update"
Increased the GPU memory available from the default of 128 to 256
ran
sudo ps aux|grep raspi"got:pi 1605 0.0 0.0 4376 508 pts/0 S+ 15:08 0:00 grep --color=auto raspi
I also tried running a program I found online:
from time import sleep
from picamera import PiCamera
camera = PiCamera()
camera.resolution = (1024, 768)
camera.start_preview()
sleep(2)
camera.capture('test_photo.jpg')
but it gives me the folliwing errors:
mmal: mmal_vc_port_enable: failed to enable port vc.null_sink:in:0(OPQV): ENOSPC
mmal: mmal_port_enable: failed to enable connected port (vc.null_sink:in:0(OPQV))0x23439e0 (ENOSPC)
mmal: mmal_connection_enable: output port couldn't be enabled
File "camera.py", line 6, in <module>
camera = PiCamera()
File "/home/pi/.local/lib/python2.7/site-packages/picamera/camera.py", line 433, in __init__
self._init_preview()
File "/home/pi/.local/lib/python2.7/site-packages/picamera/camera.py", line 513, in _init_preview
self, self._camera.outputs[self.CAMERA_PREVIEW_PORT])
File "/home/pi/.local/lib/python2.7/site-packages/picamera/renderers.py", line 558, in __init__
self.renderer.inputs[0].connect(source).enable()
File "/home/pi/.local/lib/python2.7/site-packages/picamera/mmalobj.py", line 2212, in enable
prefix="Failed to enable connection")
File "/home/pi/.local/lib/python2.7/site-packages/picamera/exc.py", line 184, in mmal_check
raise PiCameraMMALError(status, prefix)
picamera.exc.PiCameraMMALError: Failed to enable connection: Out of resources
I am new to Linux and raspberry pi, please let me know if there is anything else I could try other than changing the camera module.
because right know I think the camera modual is faulty but can that be if sudo vcgencmd get_camera
returns
supported=1 detected=1?
any help will be appreciated. thank you and have a nice day!
