I just started Raspberry pi and was ordered to get vim installed. However whenever I run sudo apt-get install vim I get the following errors:
Err:1 http://raspbian.raspberrypi.org/raspbian stretch/main armhf vim-runtime all 2:8.0.0197-4+deb9u1 Connection failed [IP: 93.93.128.193 80] E: Failed to fetch
http://raspbian.raspberrypi.org/raspbian/pool/main/v/vim/vim_8.0.0197-4+deb9u1_armhf.deb Connection failed [IP: 93.93.128.193 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
So this time I run sudo apt-get update which works perfectly (unlike Ubuntu, typing sudo isn't asking me password)
Then I do sudo apt-get upgrade. which returns 83 errors, I paste here some of them:
Err:1 http://raspbian.mirror.net.in/raspbian/raspbian stretch/main armhf base-files armhf 9.9+rpi1+deb9u8 403 Forbidden
and
E: Failed to fetch http://raspbian.mirror.net.in/raspbian/raspbian/pool/main/b/base-files/base-files_9.9+rpi1+deb9u8_armhf.deb 403 Forbidden
Research from my side tells me that I should do this:
sudo rm /var/lib/dpkg/status
sudo touch /var/lib/dpkg/status
but I don't have any /dpkg in my /lib
Solution 2 that didn't work for me:
edit /etc/apt/sources.list and replace http://mirrordirector.raspbian.org/raspbian with a mirror address from https://www.raspbian.org/RaspbianMirrors (from the website: https://www.raspberrypi.org/forums/viewtopic.php?t=123260)
because my source.list file looks nothing like mentioned above, so I didn't messed with it.
Breakpoint
  • 151
  • Did you intentionally word wrap the text? It is almost unreadable. – RalfFriedl Mar 08 '19 at 07:27
  • @RalfFriedl sorry, I did. I thought it will make errors more stand out and easy to read. It turned out to be a bad idea. I'm editing it – Breakpoint Mar 08 '19 at 07:31
  • Try again there's been some Raspbian mirroring problems this week. You'll also want vim-full to get all of the sensible vim options working. – Dougie Mar 08 '19 at 07:42
  • Thankyou @Dougie. I have been trying for last three hours. Right now, I'll report this error as something at their (raspberry pi)end. I hope it works soon! – Breakpoint Mar 08 '19 at 07:44
  • I have same issue and in my case it was caused by application firewall Fortinet which block traffic to repository sites. – Rohlik Jan 29 '22 at 14:38
Maybe your package list files are messed. You can try to reinitialize them. You can do it by deleting the list files but that is the brute force method. I suggest to do it under control of the package manager so it has a chance to notice the changes. How to do it you can look at Raspberry Pi sudo apt-get update not working.
  • 42,107
  • 85
  • 197
