I have installed the latest Raspbian Light on my new Raspberry 3B+ then followed the tutorial here:
https://www.raspberrypi.org/documentation/configuration/wireless/access-point.md
My system is:
$ uname -a
Linux raspberrypi 4.14.79-v7+ #1159 SMP Sun Nov 4 17:50:20 GMT 2018 armv7l GNU/Linux
After completed the procedure, I cannot see any SSID NameOfNetwork with an external device. wlan0 seems not active:
wlan0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether b8:27:eb:d5:30:24 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
And it seems wlan0 does not exist:
sudo ifup wlan0
ifup: unknown interface wlan0
To summarize what I did:
- Add static IP for
wlan0in/etc/dhcpd.conf - Configure a DHCP server on
wlan0in/etc/dnsmasq.conf - COnfigure hostapd in
/etc/hostapd/hostapd.conf - Bind
hostapdin/etc/default/hostapd - Start the services
hostapd,dnsmasq
It seems WPA supplicant is inactive at this point:
sudo systemctl status wpa_supplicant.service
● wpa_supplicant.service - WPA supplicant
Loaded: loaded (/lib/systemd/system/wpa_supplicant.service; disabled; vendor preset: enabled)
Active: inactive (dead)
So I started it:
But still, my Wi-Fi is not yet working
I tried to start wpa_supplicant manually:
sudo wpa_supplicant -B -iwlan0 -c/etc/wpa_supplicant/wpa_supplicant.conf
Successfully initialized wpa_supplicant
ctrl_iface exists and seems to be in use - cannot override it
Delete '/var/run/wpa_supplicant/wlan0' manually if it is not used anymore
Failed to initialize control interface 'DIR=/var/run/wpa_supplicant GROUP=netdev'.
You may have another wpa_supplicant process already running or the file was
left by an unclean termination of wpa_supplicant in which case you will need
to manually remove this file before starting wpa_supplicant again.
nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Then the configuration of the wireless device
iwconfig
eth0 no wireless extensions.
lo no wireless extensions.
wlan0 IEEE 802.11 ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=31 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:on
What should I do?
sudo systemctl start hostapd.service. An check it withsystemctl status hostapd.service– jake Feb 28 '19 at 01:06
