I have hostapd and dnsmasq running on a RPi which I have configured to broadcast a local wifi network and assign connected wireless devices an address in the 192.169.1.x range.
What I want to achieve is connect a physical computer to the RPi on its ethernet port and also have it assigned an address on the same network.
Is that possible?
Basically I want the RPi to function as if it were a router with some ethernet ports on it.
This would then show wlan0 and eth0 interfaces as being assigned an address in the 192.169.1.x range. My wlan0 interface currently has a static IP.
To have the access point and the ethernet port using the same ip address range, means using the same subnet, you have to setup a bridge br0 and then add as members the interfaces eth0 and wlan0.
Because you are already use hostapd and dnsmasq you may have a look at Setting up a Raspberry Pi as an access point in a standalone network (NAT) how to do it with this programs.
If you like to configure it with built-in components then you should have a look at Setting up a Raspberry Pi as an access point - the easy way, section Setting up an access point with a bridge.
  • 42,107
  • 85
  • 197
