Ok, so i might have messed up a bit my system and now i am unable to set a static ip through /etc/dhcpcd.conf
I'm running raspbian stretch on pi zero w
here is what i have done: I followed this link https://www.raspberrypi.org/documentation/configuration/wireless/access-point.md to set pi as access point then it turned out not exactly what i want as i only need to have DHCP server running on the pi, so i attempted to undo the changes I made I did
sudo apt-get remove hostapd dnsmasq
, however if i run
sudo systemctl status hostapd
i see its still active!
basically i have undone every step i made in that tutorial except these two which i couldn't figure out how to undo that or reset to default so not sure if its source of problem here..
Add a masquerade for outbound traffic on eth0:
sudo iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE
Save the iptables rule.
sudo sh -c "iptables-save > /etc/iptables.ipv4.nat"
my /etc/dhcpcd.conf:
Allow users of this group to interact with dhcpcd via the control socket.
#controlgroup wheel
Inform the DHCP server of our hostname for DDNS.
hostname
Use the hardware address of the interface for the Client ID.
clientid
or
Use the same DUID + IAID as set in DHCPv6 for DHCPv4 ClientID as per RFC4361.
Some non-RFC compliant DHCP servers do not reply with this set.
In this case, comment out duid and enable clientid above.
#duid
Persist interface configuration when dhcpcd exits.
persistent
Rapid commit support.
Safe to enable by default because it requires the equivalent option set
on the server to actually work.
option rapid_commit
A list of options to request from the DHCP server.
Most distributions have NTP support.
option ntp_servers
Respect the network MTU. This is applied to DHCP routes.
option interface_mtu
A ServerID is required by RFC2131.
Generate Stable Private IPv6 Addresses instead of hardware based ones
slaac private
Example static IP configuration:
#interface eth0
#static ip_address=192.168.0.10/24
#static ip6_address=fd51:42f8:caae:d92e::ff/64
#static routers=192.168.0.1
#static domain_name_servers=192.168.0.1 8.8.8.8 fd51:42f8:caae:d92e::1
It is possible to fall back to a static IP if DHCP fails:
define static profile
#profile static_eth0
#static ip_address=192.168.1.23/24
#static routers=192.168.1.1
#static domain_name_servers=192.168.1.1
fallback to static profile on eth0
#interface eth0
#fallback static_eth0
interface wlan0
static ip_address=192.168.4.1/24
nohook wpa_supplicant
output of ifconfig:
RX packets 370 bytes 34870 (34.0 KiB)
TX packets 370 bytes 34870 (34.0 KiB)
usb0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 169.254.51.119 netmask 255.255.0.0 broadcast 169.254.255.255
inet6 fe80::ede7:ac03:2417:f53d prefixlen 64 scopeid 0x20<link>
ether 86:03:1c:a1:7e:d9 txqueuelen 1000 (Ethernet)
RX packets 1616 bytes 149330 (145.8 KiB)
RX errors 0 dropped 4 overruns 0 frame 0
TX packets 1722 bytes 269309 (262.9 KiB)
wlan0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether b8:27:eb:e9:6f:91 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
I don't know why it is not setting the static ip address 192.168.4.1 on interface wlan0?!
update1:
outpu of systemctl status dhcpcd.service
● dhcpcd.service - dhcpcd on all interfaces
Loaded: loaded (/lib/systemd/system/dhcpcd.service; enabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/dhcpcd.service.d
└─wait.conf
Active: active (running) since Tue 2019-02-12 08:33:46 UTC; 4min 1s ago
Process: 241 ExecStart=/usr/lib/dhcpcd5/dhcpcd -q -w (code=exited, status=0/SUCCESS)
Main PID: 398 (dhcpcd)
CGroup: /system.slice/dhcpcd.service
├─345 wpa_supplicant -B -c/etc/wpa_supplicant/wpa_supplicant.conf -iwlan0 -Dnl80211,wext
└─398 /sbin/dhcpcd -q -w
Feb 12 08:33:39 raspi-goggles dhcpcd[241]: wlan0: probing address 192.168.6.1/24
Feb 12 08:33:39 raspi-goggles dhcpcd[241]: wlan0: carrier lost
Feb 12 08:33:39 raspi-goggles dhcpcd[241]: wlan0: deleting address fe80::987c:c17a:851a:c67c
Feb 12 08:33:40 raspi-goggles dhcpcd[241]: usb0: probing for an IPv4LL address
Feb 12 08:33:46 raspi-goggles dhcpcd[241]: usb0: using IPv4LL address 169.254.100.26
Feb 12 08:33:46 raspi-goggles dhcpcd[241]: usb0: adding route to 169.254.0.0/16
Feb 12 08:33:46 raspi-goggles dhcpcd[241]: usb0: adding default route
Feb 12 08:33:46 raspi-goggles dhcpcd[241]: forked to background, child pid 398
Feb 12 08:33:46 raspi-goggles systemd[1]: Started dhcpcd on all interfaces.
Feb 12 08:33:49 raspi-goggles dhcpcd[398]: usb0: no IPv6 Routers available
Warning: dhcpcd.service changed on disk. Run 'systemctl daemon-reload' to reload units.
update 2: I found out something that might be interesting:
if I add valid network credentials to /etc/wpa_supplicant/wpa_supplicant.conf such as:
network={
ssid="valid_ssid"
psk="valid_passphrase"
key_mgmt=WPA-PSK
the static ip in /etc/dhcpcd.conf works however, if i put wrong values for network t doesn't. I don't really understand why is that, but I don't want to use vlaid credentials because I am not expecting the Pi to be connected to another LAN, I only want to give it a static ip and run a dhcp server on it and enable wifi p2p where other devices can connect to it.
