New to Raspberry pi so this may be a rookie problem. I installed Raspbian as per instructions and all seems well, including browsing, compilations etc. I am connected via wifi and ifconfig shows a valid ip address for wlan0.
ping 127.0.0.0 gives:
pi@raspberrypi:~ $ ping 127.0.0.1
PING 127.0.0.1 (127.0.0.1) 56(84) bytes of data.
64 bytes from 127.0.0.1: icmp_seq=1 ttl=64 time=0.102 ms
64 bytes from 127.0.0.1: icmp_seq=2 ttl=64 time=0.119 ms
ping google.com gives:
PING google.com(syd09s12-in-x0e.1e100.net (2404:6800:4006:803::200e)) 56 data bytes
^C
--- google.com ping statistics ---
645 packets transmitted, 0 received, 100% packet loss, time 669783ms
So clearly not working. What am I doing wrong? Same result for all external addresses - but Chromium working fine.
Here is the config output is that helps:
pi@raspberrypi:~ $ ifconfig -a
eth0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether b8:27:eb:ec:f0:2c  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 32  bytes 2968 (2.8 KiB)
        TX packets 32  bytes 2968 (2.8 KiB)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 10.0.0.32  netmask 255.255.255.0  broadcast 10.0.0.255
        inet6 2001:8003:890f:c000:9a9b:2baa:67db:a48b  prefixlen 64  scopeid 0x0<global>
        inet6 fe80::bf92:3e2a:3ede:678  prefixlen 64  scopeid 0x20<link>
        ether b8:27:eb:b9:a5:79  txqueuelen 1000  (Ethernet)
        RX packets 3109  bytes 1605135 (1.5 MiB)
        TX packets 3909  bytes 521901 (509.6 KiB)
ping -4 google.com- see if it's some ipv6 issue (did not realise telstra issued ipv6 yet) – Jaromanda X Jan 31 '19 at 03:32
