I've followed the excellent instructions at Setting up a Raspberry Pi as an access point - the easy way and have succeeded in setting up my Raspi 3b as a router (Ethernet on the uplink on subnet 192.168.6.0/24, WiFi AP on the internal side with subnet 192.168.8.0/24). Everything is perfect, with an SSID of foo2. However, if I edit the /etc/wpa_supplicant/wpa_supplicant-wlan0.conf file to change the SSID to foo and reboot, nothing can connect. The symptom from the client devices (Android "NETWORK_SELECTION_DISABLED_ASSOCIATION_REJECTION", chromebook "Out of Range", Ubuntu laptop "") is that of an incorrect password. So the foo SSID is visible, and a connection attempt is made, but it fails.
My reason for changing the SSID from foo2 to foo is because I have an existing Ethernet/WiFi router that I'm looking for the Raspi to replace. So once I got the Raspi working, I changed the SSID to that of the old device, which I have turned off.
On the client devices I've tried forgetting the original foo network and reentering the password, but still no joy. All SSIDS (original foo, new foo) have the same password.
My Router
/ \ 192.168.6.0/24
Old device Raspi foo and foo2 both work
foo foo2 192.168.8.0/24
______________________________________
My Router
/ \ 192.168.6.0/24
Raspi foo does not work
foo 192.168.8.0/24
I'm seeing WPA: wpa_sm_step() called recursively in the Raspi syslog. I also think I saw that the log file in my failing dhcp-client contains references to the wrong mac address. So maybe there is an ARP cache issue somewhere in the dhcp implementation.
foo2SSID. The difference between a working and non-working scenario is literally one character. I've also triedfo2to see if a short SSID was the issue, but that works OK. – pinoyyid Jan 25 '19 at 13:38I've just read https://raspberrypi.stackexchange.com/questions/78817/wifi-access-point-works-but-not-when-roaming-between-networks-of-the-same-ssid
- Could it be a DHCP issue? and in your instructions how would I configure the DHCP options, eg to set authorative mode or define an address range that is available to DHCP clients?
– pinoyyid Jan 25 '19 at 14:52WPA: wpa_sm_step() called recursivelyin the Raspi syslog. I also think I saw that the log file in my failing dhcp-client contains references to the wrong mac address. So maybe there is an ARP cache issue somewhere in the dhcp implementation. Please don't go to too much trouble just for me. I've decided not to waste any more time trying to fix it when I can buy a 20euro device from Amazon to do the job I need. – pinoyyid Jan 27 '19 at 01:24
