i try to create a free vpn client of raspberry pi 3 to hide my ip address when i connect to the internet.to do that i install an openvpn from vpnbook.com on my rasbian stretch OS. this is what i do:
sudo apt-get update
sudo apt-get install openvpn
cd /etc/openvpn/
sudo wget https://certificate-vpnbook
sudo unzip certificate
sudo nano password.txt
vpnbook
i run this command:
sudo openvpn vpnbook-pl226-udp53.ovpn
and get this error:
WARNING: file '/etc/openvpn/password.txt' is group or others accessible
penVPN 2.4.0 arm-unknown-linux-gnueabihf [SSL (OpenSSL)] [LZO] [LZ4]
[EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on Jul 18 2017
library versions: OpenSSL 1.0.2q 20 Nov 2018, LZO 2.08
WARNING: No server certificate verification method has been enabled. See
http://openvpn.net/howto.html#mitm for more info.
TCP/UDP: Preserving recently used remote address: [AF_INET
Socket Buffers: R=[163840->163840] S=[163840->163840]
UDP link local: (not bound)
UDP link remote: [AF_INET]51.68.152.226:53
TLS Error: TLS key negotiation failed to occur within 60 seconds (check
your network connectivity)
TLS Error: TLS handshake failed
SIGUSR1[soft,tls-error] received, process restarting
i also change the DNS address in this file: /etc/openvpn/server.conf from google dns server:
push "dhcp-option DNS 8.8.8.8"
push "dhcp-option DNS 8.8.4.4"
to
push "dhcp-option DNS 208.67.222.222"
push "dhcp-option DNS 208.67.220.220"
i search the warning and the result are about vpn server and mine is vpn client. i don't know how to solve my problem. i appreciate your help.
chmod 600) – Charemer Jan 03 '19 at 12:37
