I know how to backup system image, but what if I want to restore the image to a different size of SD card that does not match the one I backup from? Generally 2 cases: 1. The source SD card is 16G, but I just used like 3-4G, I would like restore it on a 8G SD card. 2. The source SD card is 16G, and I just need to enlarge the space by replace it with a 64GB card, how can I extend the space after write the image?
Asked
Active
Viewed 28 times
dd. This works, but it is arguably the worst method that does -- partially because it is inflexible, which is the problem you have now. However, you can probably mount it and copy the contents onto a card of whatever size, if you read some of the stuff in the duplicate Q&A. – goldilocks Dec 27 '18 at 15:32
