I am running Raspbian on my Pi 2 and am currently remoted in using VNC Viewer - for some reason, whenever I try to use File Manager (through the Taskbar or otherwise) the window will open, then auto close, and the desktop will flicker momentarily. I'm not sure what's going on, as Wolframalpha, Terminal and the Browser icons all work. Is there a way I can check what's causing this issue?
Update: After running pcmanfm in the terminal, it appears I'm getting a segmentation fault - there are no other errors simply the following:
pi@mediaserver:~ $ pcmanfm
** Message: 09:18:54.081: x-terminal-emulator has very limited support, consider choose another terminal
Segmentation fault
which makes it kind of hard to pin down the solution
pcmanfm. Have a look at any (error) messages. Add any updates to your question using blockquote (icon with curly brackets) – Dirk Dec 24 '18 at 08:23pcmanfm ./from a terminal window that was on my home folder. Then pcmanfm started normall and I was able to start it again from the taskbar shortcut. – bart s Apr 28 '20 at 10:03
