In order to reach my Raspberry Pi 3 B +, I need it to broadcast an access point upon booting.
I am aware that there are common issues with crontab @reboot and systemctl running when networking is still down.
I have a working access point setup; however, the code seems to fail only when started through a service, ap.
When I manually execute the following script, ap.sh
, it successfully initiates an access point (touch yes.txt
lets me know it has run):
#!/bin/bash
cd /home/pi/ap/
sleep 30
ifconfig wlan0 down
iwconfig wlan0 mode monitor
ifconfig wlan0 up
ifconfig wlan0 up 192.168.1.1 netmask 255.255.255.0
hostapd hostapd.conf &
touch yes.txt
(hostapd hostapd.conf &
works, along with the rest of ap.sh
However, as I mentioned before, I need a service to run this script, and so I made ap.service
[Install]
WantedBy=multi-user.target
[Unit]
Description=Access Point Service
Wants=network-online.target
After=network-online.target
[Service]
User=root
Group=root
ExecStart=/home/pi/ap/ap.sh
ExecStartPre=/bin/sleep 10
Type=simple
After my Pi boots, I see the following message when I check service status ap
Nov 17 00:27:18 raspberrypi systemd[1]: Starting Access Point Service...
Nov 17 00:27:28 raspberrypi systemd[1]: Started Access Point Service.
Nov 17 00:27:28 raspberrypi ap.sh[590]: Error for wireless request "Set Mode" (8B06) :
Nov 17 00:27:28 raspberrypi ap.sh[590]: SET failed on device wlan0 ; Operation not supported.
As I understand it, the error is being thrown by hostapd. I'm not sure why though, since ap.sh
works perfectly well and the ap
service is run by root.
Also, the service successfully sleeps for thirty seconds, initiates wlan0
with an IP address, and creates yes.txt
in /home/pi/ap
, meaning that the failure seems to be isolated in hostapd
Any help would be much appreciated!
