Running Raspbian installed with NOOBS. qjackctl is installed with all its dependencies using Synaptic. Just trying to run Guitarix on my Pi3 B+. I tried following the instructions in this solution, but the ../configure... command at the end just returned an error about missing directories. Help is appreciated, this is my first time using a Pi or Linux.
Possible duplicate of Qt applications don't work due to libEGL – Dirk Dec 19 '18 at 20:01
1@Dirk That is what the OP followed but doesn't work :) – Ingo Dec 19 '18 at 22:15
1Welcome to the Raspberry Pi flavoured corner of the Stack Exchange network - you may wish to take the tour which may help you to ask questions that furnish good replies. – SlySven Dec 20 '18 at 04:02
1There's not enough information provided here to answer your question - or really to understand fully what your question is. We'll need, for example, the specific errors that you got. Maybe more. – Brick Dec 20 '18 at 14:37
And while you're at it, check if the directory in question is really missing or not accessible to the build script. – Dmitry Grigoryev Sep 16 '22 at 21:03
According to https://www.raspberrypi.org/forums/viewtopic.php?p=971944 and from my own coding experience (I code for a macOs/Windows/Linux project that makes use of the Qt Libs) the RPi's OpenGLES is the embedded form which is not the same as a full Desktop system OpenGL - and some OpenGL stuff does not work on it (sadly that includes the oldest simplest direct OpenGL 1.0 stuff that is exactly what the project I code for uses).
I tried to build this on my RPi and after cloning the Guitarix project (from my ~/src/ directory): git clone http://git.code.sf.net/p/guitarix/git ./guitarix and after changing to the ~/src/guitarix/trunk/ directory and failing to run the command: ./waf --configure through to successful completion, I needed to work my way through finding and installing needed things - though you should be able to do all the package installation steps (with other associated pacakages) at one swell foop:
- create a symbolic link from gcc/g++ to gcc-6/g++-6:
sudo ln -s -i /usr/bin/gcc-6 /usr/bin/gccandsudo ln -s -i /usr/bin/g++-6 /usr/bin/g++ - install intltool and gettext-devel packages:
sudo apt-get install intltool gettext-devel - install sndfile containing package:
sudo apt-get install libsndfile-dev - install gthread containing package:
sudo apt-get install libglib2.0-dev - install glibmm-2.4 containing package:
sudo apt-get install libgmm-2.4 - install header fftw3.f containing package:
sudo apt-get install libfftw3-dev - install libcurl containing package:
sudo apt-get install libcurl4-gnutls-dev{note this virtual package could also be provided by:libcurl4-openssl-devorlibcurl4-nss-devbut since I already hadlibcurl3I suspected the later version (and its development headers) would be the most straightforward to use} - install jack >= 1.9.2 containing package:
sudo apt get install libjack-jackd2-dev{note this installs the jack 1.9.10 version currently} - install gkt+-2.0 >= 2.20 containing package:
libgtk2.0-dev libpango1.0-dev libcairo2-dev
Unfortunately I hit a - hopefully temporary - blockage in that the RPi is currently using libcairo2 and libcairo-gobject2 at version 1.14.8-1+rpi (i.e. an Raspberry Pi special compilation of those two - the unmodified versions are also available as 1.14.8-1) however libcairo2 is only listed as a version 1.14.8-1 and it only accepts the other libcairo packages without the suffix. I have found this Raspberry Pi forum article about it: "Unable to install libgtk2.0-dev on Raspberry Pi 2" and I have reported my findings and my suspicions that we need a libcairo2-dev version 1.14.8-1+rpi with a dependency on the other suffixed packages.
~That is all I can find out at the moment - I hope I can update this when this issue is sorted...~
Update: Seems that in the past I experimented with a different repository and have got some problems to sort out in that- given that I am away from home (and my RPi) for a few days I cannot do anything until I get back.
- 3,621
- 18
- 45
