I'm following raspberrypi.org THE RASPBERRY PI UARTS guide, trying to connect from mac 10.13.6 High Sierra to Pi 3 using screen.
I had to disable system integrity protection on mac (high sierra) to get the cp1202 kext loaded. Once i did that, i was able to see the /dev/cu.SLAB_USBtoUART. I tried connecting using screen, but saw only garbage characters. I have disabled hciuart service, disabled serial login shell (kinda odd, but that's what the guide suggests), still only seeing garbage.
To clarify, I'm trying to establish a serial connection from mac to PI, so i can get to PI's shell via screen (for example) from mac.
Any help is much appreciated!
cp2102 drivers I'm using
end of /boot/config.txt
# Additional overlays and parameters are documented
/boot/overlays/README
# Disabling Bluetooth overlay
dtoverlay=pi3-disable-bt
dtoverlay=pi3-miniuart-bt
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
# NOOBS Auto-generated Settings:^M
hdmi_force_hotplug=1^M
enable_uart=1
gpu_mem=128
/boot/cmdline.txt
dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p7 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
/lib/systemd/system/hciuart.service
[Unit]
Description=Configure Bluetooth Modems connected by UART
ConditionPathIsDirectory=/proc/device-tree/soc/gpio@7e200000/bt_pins
Before=bluetooth.service
After=dev-serial1.device
[Service]
Type=forking
ExecStart=/usr/bin/btuart
[Install]
WantedBy=multi-user.target
pi3-miniuart-bt switches the Raspberry Pi 3 and Raspberry Pi Zero W Bluetooth function to use the mini UART (ttyS0), and restores UART0/ttyAMA0 to GPIOs 14 and 15.
Similar things are written in the link you posted. Still, connecting from mac to pi does not give me shell, and when i reboot i see garbage.
– Alex Dec 02 '18 at 04:43
