I believe I figured it out after quite some fiddling.
What is the most specific parameter I can use to be compatible with all models?
Raspbian FAQ's contain the final answer:
-march=armv6
-mfpu=vfp
-mfloat-abi=hard
Note that the packages in Debian compiled for the armhf architecture are not the same as in Raspbian: Raspbian has been derived from Debian specifically to contain binaries for armv6; the armhf architecture in Debian is compiled for armv7, not v6.
This is reinforced by inspecting a binary in Raspbian using readelf -a -W from binutils:
Tag_CPU_name: "6"
Tag_CPU_arch: v6
Tag_THUMB_ISA_use: Thumb-1
Tag_FP_arch: VFPv2
Tag_ABI_VFP_args: VFP registers
Tag_CPU_unaligned_access: v6
(this is /usr/bin/g++-6 from the g++-6 package in Raspbian Stretch). Note that you would get a different answer (namely ARM 7) if you were to inspect the package with the same name in Debian!
Is there even a difference between armv6, armv6z, armv6zk and armv6l?
I figured the suffix l stands for "little endian", m, z and k are actual microarchitectures.
This means that my Raspberry Pi has an actual armv6, a revision 000d with the following features:
Model name: ARMv6-compatible processor rev 7 (v6l)
Flags: half thumb fastmult vfp edsp java tls
(obtained by running lscpu). There is a bit of confusion on Z and K, but I think the best way to illustrate the difference between these architectures (rather than digging up the official papers by ARM) is looking into LLVM's definition at llvm/lib/Target/ARM/ARM.td for these architectures:
def ARMv6 : Architecture<"armv6", "ARMv6", [HasV6Ops,
FeatureDSP]>;
def ARMv6t2 : Architecture<"armv6t2", "ARMv6t2", [HasV6T2Ops,
FeatureDSP]>;
def ARMv6k : Architecture<"armv6k", "ARMv6k", [HasV6KOps]>;
def ARMv6kz : Architecture<"armv6kz", "ARMv6kz", [HasV6KOps,
FeatureTrustZone]>;
def ARMv6m : Architecture<"armv6-m", "ARMv6m", [HasV6MOps,
FeatureNoARM,
ModeThumb,
FeatureDB,
FeatureMClass,
FeatureStrictAlign]>;
def ARMv6sm : Architecture<"armv6s-m", "ARMv6sm", [HasV6MOps,
FeatureNoARM,
ModeThumb,
FeatureDB,
FeatureMClass,
What is the exact architecture parameter for each Raspberry Pi model?
Now that some light was shed on the acronyms, from RPi's website:
- Raspberry Pi 1, Model A, B, B+, the Compute Module, and the Raspberry Pi Zero: ARM11 76JZF-S, which is part of the ARM11 family has
armv6, in a BCM2835 SoC.
- Raspberry Pi 2 Model B, rev 1.1: ARM Cortex-A7, part of the Cortex-A family has
armv7a in a BCM2836 SoC.
- Raspberry Pi 2, rev 1.2, and Raspberry Pi 3: ARM Cortex-A53, also Cortex-A family, has
armv8a, in a BCM2837 SoC.
- Raspberry Pi 3 A+ and B+: ARM Cortex-A53, thus
armv8a in a BCM2837B0 SoC.
The list above not include the various extra features, such as Thumb.
