This question is in relation with the following landmark article: How do I set up networking/WiFi/static IP address?
I have a raspberry PI3B+ with raspbian stretch lite (2018-10-09-raspbian-stretch-lite version) Predictable network interface names is disabled. My network card topology is as such:
- eth0 connected via ethernet cable to a wrt54gl router with DHCP server on it.
- wlan0 connected to my HUAWEI phone hotspot.
- wlan1 is a TP-LINK TL-WN722N USB dongle which I need to configure with a static IP address for future setup as an access point.
Having tinkered with the /etc/network/interfaces for a while intending to configure my network as per most tutorials on the web, I came upon the article How do I set up networking/WiFi/static IP address? which basically explains how the way to configure network parameters is now different in Raspbian Stretch. I therefore updated my configuration files as such:
/etc/network/interfaces file is deleted
/etc/dhcpcd.conf file is appended with the following lines at the bottom:
interface wlan1 nohook wpa_supplicant static ip_address=192.168.3.1/24 denyinterfaces wlan1
- /etc/wpa_supplicant/wpa_supplicant.conf is as such:
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev update_config=1 country=FR network= { ssid="HUAWEI" psk="xxxxxxx" }
After I boot:
- eth0 connects correctly to the router it is hook up with and receives IP address through said router's DHCP server.
- wlan0 connects correctly to the HUAWEI hotspot and receives an IP address through it.
- wlan1 does not connect to HUAWEI (correctly applied the nohook argument). However it does not receive the 192.168.3.1 ip address as shown in the ifconfig screenshot bellow:
wlan1: flags=4099 mtu 1500 ether b8:27:eb:3b:f7:6f txqueuelen 1000 (Ethernet) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
I have tried to include a static IP for wlan1 in /etc/network/interfaces which doesnt work and takes every interface down.
I have also tried to add a post-up script in the same file to the same effect.
Question: Is there an actual way to configure a static IP from /etc/dhcpcd.conf or do I need to disable the DHCP client daemon and revert to using /etc/network/interfaces for my network setup (aka the old way)?
PS: I know I can manually set the IP after boot or script this, but would rather try to understand how to do it correctly via dhcpcd.
EDIT:
After enabling Predictable network interface names, and updating the dhcp.conf file accordingly I still cannot get a fixed IP from dhpcd for the USB wifi dongle. Bellow the updates and results for 2 different USB dongles.
With TP-LINK TL-WN722N
/etc/dhcpcd.conf
interface wlxc025e91f7d7f
After reboot
pi@raspberrypi:~ $ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group
default qlen 1000
inet6 ::1/128 scope host
2: enxb827eb6ea23a: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc
pfifo_fast state UP group default qlen 1000
link/ether b8:27:eb:6e:a2:3a brd ff:ff:ff:ff:ff:ff
inet 192.168.2.112/24 brd 192.168.2.255 scope global enxb827eb6ea23a
inet6 fe80::718c:2ecd:b4fb:5196/64 scope link
3: wlxc025e91f7d7f: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq
state DOWN group default qlen 1000
link/ether c0:25:e9:1f:7d:7f brd ff:ff:ff:ff:ff:ff
4: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state
link/ether b8:27:eb:3b:f7:6f brd ff:ff:ff:ff:ff:ff
inet 192.168.43.245/24 brd 192.168.43.255 scope global wlan0
inet6 fe80::9e31:7338:af4e:2b1/64 scope link
And there is only 1 line in the dhcp client log
pi@raspberrypi:~ $ journalctl -u dhcpcd | grep wlxc025e91f7d7f
Nov 27 08:33:52 raspberrypi dhcpcd[308]: wlxc025e91f7d7f: waiting for
carrier
While with Alfa AWUS036NHA
/etc/dhcpcd.conf
interface wlx00c0ca979610
After reboot
default qlen 1000
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state
4: wlx00c0ca979610: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq
link/ether 00:c0:ca:97:96:10 brd ff:ff:ff:ff:ff:ff
The DHCPCD service first probed the fixed IP address to the interface before removing it.
pi@raspberrypi:~ $ journalctl -u dhcpcd | grep wlx00c0ca979610
Nov 27 08:42:53 raspberrypi dhcpcd[335]: wlx00c0ca979610: waiting for
carrier
Nov 27 08:42:53 raspberrypi dhcpcd[335]: wlx00c0ca979610: carrier acquired
Nov 27 08:42:53 raspberrypi dhcpcd[335]: wlx00c0ca979610: IAID ca:97:96:10
Nov 27 08:42:53 raspberrypi dhcpcd[335]: wlx00c0ca979610: adding address
fe80::82f3:e742:c3cd:1379
Nov 27 08:42:53 raspberrypi dhcpcd[335]: wlx00c0ca979610: probing address
192.168.3.1/24
Nov 27 08:42:53 raspberrypi dhcpcd[335]: wlx00c0ca979610: carrier lost
Nov 27 08:42:53 raspberrypi dhcpcd[335]: wlx00c0ca979610: deleting address
FYI with the /etc/dhcpcd.conf file left totally empty, both USB dongle connect fine to any wifi specified in the /etc/wpa_supplicant/wpa_supplicant.conf file.
wpa_supplicant-wlan0
for wlan0, etc) – Dirk Nov 22 '18 at 22:16
