I'm trying to set a static IP for my Pi Zero's USB ethernet port using /etc/dhcpcd.conf
. I'm using Raspbian Stretch.
Here is my /etc/dhcpcd.conf
file:
pi@raspberrypi:~ $ cat /etc/dhcpcd.conf
#controlgroup wheel
# Inform the DHCP server of our hostname for DDNS.
hostname
# Use the hardware address of the interface for the Client ID.
clientid
# or
# Use the same DUID + IAID as set in DHCPv6 for DHCPv4 ClientID as per RFC4361.
# Some non-RFC compliant DHCP servers do not reply with this set.
# In this case, comment out duid and enable clientid above.
#duid
# Persist interface configuration when dhcpcd exits.
persistent
# Rapid commit support.
# Safe to enable by default because it requires the equivalent option set
# on the server to actually work.
option rapid_commit
# A list of options to request from the DHCP server.
# Most distributions have NTP support.
option ntp_servers
# Respect the network MTU. This is applied to DHCP routes.
option interface_mtu
# A ServerID is required by RFC2131.
# Generate Stable Private IPv6 Addresses instead of hardware based ones
slaac private
# Example static IP configuration:
interface eth0
static ip_address=192.168.2.09
#static ip6_address=fd51:42f8:caae:d92e::ff/64
#static routers=192.168.0.1
#static domain_name_servers=192.168.0.1 8.8.8.8 fd51:42f8:caae:d92e::1
# It is possible to fall back to a static IP if DHCP fails:
# define static profile
#profile static_eth0
#static ip_address=192.168.1.23/24
#static routers=192.168.1.1
#static domain_name_servers=192.168.1.1
# fallback to static profile on eth0
#interface eth0
#fallback static_eth0
Notice that I set static ip_address=192.168.2.09
for eth0
However, after rebooting my Pi, when I check ifconfig
I see the following:
pi@raspberrypi:~ $ ifconfig
inet 192.168.2.161 netmask 255.255.255.0 broadcast 192.168.2.255
inet6 fe80::9f9b:41c1:8aa3:4427 prefixlen 64 scopeid 0x20<link>
ether 02:00:00:00:00:09 txqueuelen 1000 (Ethernet)
RX packets 179 bytes 14789 (14.4 KiB)
RX errors 1 dropped 0 overruns 1 frame 2
TX packets 176 bytes 22776 (22.2 KiB)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
The IP address listed for eth0 is 192.168.2.161
which I believe was set automatically by my router.
sudo systemctl status dhcpcd
yields the following output:
pi@raspberrypi:~ $ sudo systemctl status dhcpcd
● dhcpcd.service - dhcpcd on all interfaces
Loaded: loaded (/lib/systemd/system/dhcpcd.service; enabled; vendor preset: e
Active: active (running) since Tue 2018-11-20 21:12:10 UTC; 20min ago
Process: 209 ExecStart=/usr/lib/dhcpcd5/dhcpcd -q -b (code=exited, status=0/SU
Main PID: 232 (dhcpcd)
CGroup: /system.slice/dhcpcd.service
└─232 /sbin/dhcpcd -q -b
Nov 20 21:12:13 raspberrypi dhcpcd[232]: eth0: IAID 00:00:00:09
Nov 20 21:12:13 raspberrypi dhcpcd[232]: eth0: adding address fe80::9f9b:41c1:8a
Nov 20 21:12:14 raspberrypi dhcpcd[232]: eth0: soliciting a DHCP lease
Nov 20 21:12:14 raspberrypi dhcpcd[232]: eth0: soliciting an IPv6 router
Nov 20 21:12:14 raspberrypi dhcpcd[232]: eth0: offered 192.168.2.161 from 192.16
Nov 20 21:12:15 raspberrypi dhcpcd[232]: eth0: probing address 192.168.2.161/24
Nov 20 21:12:20 raspberrypi dhcpcd[232]: eth0: leased 192.168.2.161 for 259200 s
Nov 20 21:12:20 raspberrypi dhcpcd[232]: eth0: adding route to 192.168.2.0/24
Nov 20 21:12:20 raspberrypi dhcpcd[232]: eth0: adding default route via 192.168.
Nov 20 21:12:27 raspberrypi dhcpcd[232]: eth0: no IPv6 Routers available
lines 1-18/18 (END)
Why isn't the static IP change taking effect?
– RubberStamp Nov 20 '18 at 21:25sudo systemctl status dhcpcd` – Matt Nov 20 '18 at 21:34
09
should simply be9
....192.168.2.9
rather than192.168.2.09
– RubberStamp Nov 20 '18 at 22:1809
vs.9
in the past – Matt Nov 20 '18 at 23:42
