How would I be able to use my rPi with a fixed IP on the ethernet port and 'automatic' wifi?
I've got the credentials for the known accesspoints, with priority stored in /etc/wpa_supplicant/wpa_supplicant.conf
The RPi is autoconnecting to my wifi network, and I was able to SSH into the pi. Now, to setup the static IP for the ethernetport I followed this answer, and so:
In /etc/dhcpcd.conf
I uncommented the following:
interface eth0
static ip_address=x.y.z.5/24
static routers=x.y.z.1
static domain_name_servers=1.1.1.1
Then I ran
sudo systemctl disable dhcpcd
sudo systemctl enable networking
But now the pi doesn't connect to the Wifi anymore and I cannot connect to the ethernetport as this is a completely different subnet :)
So in the end I want to have the following:
- Eth0 > static IP
- Wlan0 > DHCP, with auto connect with credentials from
wpa_supplicant.conf
The reason for this setup: I've got 5 public ip adresses with my provider; I want my pi to be on one of them. As the router itself is 'transparent' and managed by the provider I need to configure the ip settings, including gateway, for this interface manually. The wlan connection is just to configure the pi at my office (which is not the end location).
CTRL+O
then only the cursor jumps and withCTRL+X
nothing happens. – Ingo Nov 08 '18 at 10:32
