I am trying to connect my Raspberry pi 1 model b to the internet using an Edimax adapter. My pi recognises the adapter, but when I try to configure my pi to connect to my WIFI by using
sudo nano /etc/network/interfaces
My screen comes up with:
# Please note that this file is written to be used with dhcpcd.
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'.
and some other comments. When I use the command:
sudo nano /etc/dhcpcd.conf
The following appears:
#controlgroup wheel
# Inform the DHCP server of our hostname for DDNS.
hostname
# Use the hardware address of the interface for the Client ID.
clientid
# or
# Use the same DUID + IAID as set in DHCPv6 for DHCPv4 ClientID as per
RFC4361.
#duid
# Persist interface configuration when dhcpcd exits.
persistent
# Rapid commit support.
# Safe to enable by default because it requires the equivalent option set
# on the server to actually work.
option rapid_commit
# A list of options to request from the DHCP server.
# Most distributions have NTP support.
option ntp_servers
# Respect the network MTU.
# Some interface drivers reset when changing the MTU so disabled by
default.
#option interface_mtu
lsusb comes up with:
Bus 001 Device 008: ID 046:c31c Logitech, Inc. Keyboard K120
Bus 001 Device 004: ID 7392:7811 Edimax Technology Co., Ltd EW-7811Un 802.11n Wireless Adapter [Realtek RTL8188CUS]
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9524 Standard Microsystems Corp. SMC9514 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
ifconfig comes up with (For the wlan0 section):
wlan0: flags=4099<UP, BROADCAST MULTICAST> mtu 1500
ether 74:da:38:ed:45:e9 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 12 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 B)
I really am not sure what to do from here. I do apologise if this is an obvious problem, but I am new to Raspberry Pi, so if you could explain to me in a simple way how to configure the Wifi network I would really appreciate it.
Thanks!
lsusb
andifconfig
. And what protocol does your AP use? Is the SSID of the AP hidden? – Dirk Oct 30 '18 at 10:04sudo iw list
,sudo iw dev
andsudo iw dev wlan0 scan
. Just with the last command you should see all the wifi networks from your neighbors. If so then it is only a configuration issue. Follow the instructions Milliways gives in his first comment. – Ingo Oct 30 '18 at 19:30
