This is a follow up question to this post and subsequently this post.
To save you from a long read I am trying to force a MAC address change on my Pi Zero ethernet adapter with:
ifconfig eth0 down; ifconfig eth0 hw ether 21:21:21:21:00:11; ifconfig eth0 up; ifconfig eth0
But I receive the error message:
ether: Host name lookup failure
ifconfig: `--help' gives usage information.
inet6 fe80::bb7e:8c36:1a6c:4d5e prefixlen 64 scopeid 0x20<link>
ether 10:10:12:10:10:10 txqueuelen 1000 (Ethernet)
RX packets 1342 bytes 95363 (93.1 KiB)
RX errors 1 dropped 5 overruns 0 frame 1
TX packets 817 bytes 102452 (100.0 KiB)
Why can I not find ether? Many additional details leading up to this point can be found in the linked questions if needed.
1,3,5,7,9,B,D,Fwill be invalid ... the2,6,A,Ein the list are the so called "locally administered" MAC addresses - not likely to clash with a manufacturer MAC address (whose second digits would be one of0,4,8,C– Jaromanda X Oct 16 '18 at 22:1222:12:12:12:12:12I receive the exact same error message – Matt Oct 17 '18 at 00:22ifconfig eth0 down; ifconfig eth0 hw ether 10:00:00:00:00:11; ifconfig eth0 up; ifconfig eth0worked? and from the output in the questionether 10:10:12:10:10:10looks like it does – Jaromanda X Oct 17 '18 at 00:42ether: Host name lookup failure- that's a weird error to get ... type those commands one at a time ... it's definitely theifconfig eth0 hw ether ......line that triggers that error? – Jaromanda X Oct 17 '18 at 00:44eth0in one of the commands – Matt Oct 17 '18 at 00:53
