I followed the instructions here: enter link description here with the aim of getting ap and managed client wifi running together. The wlan0 setup works perfectly. I could not see any attempt to run ap0 in the journalctl.
The command:
systemctl status wpa_supplicant@ap0.service
shows that ap0 is loaded but not active.
I ran the command:
sudo systemctl start wpa_supplicant@ap0.service
The journal reported the following failure:
systemd[1]: sys-subsystem-net-devices-ap0.device: Job sys-subsystem-net-devices-ap0.device/start timed out.
Where should I look to solve this??
dazz
  • 175
  • I have deleted the answer because it wasn't accepted. If you want to refer it, I have made a new one at Access point as WiFi repeater, optional with bridge. – Ingo May 13 '19 at 12:03
  • All attempts to setup an AP with Stretch didn't work. I tried again by upgrading Stretch to Buster. Still didn't work. I then tried to setup an AP with a fresh Buster installation and it worked perfectly first time. I have decided not to try to setup in AP and client at the same time. – dazz Jul 11 '19 at 10:59
0 Answers0
