i read all of the posts here and commentated on one of them but comment was deleted as it was a question i guess, so i mage my own now, sorry for that...
Ok the problem:
USB sound card mic is not working, but when i edit the ~/.asoundrc to:
pcm.!default {
  type plug
  slave {
    pcm "hw:1,0"
ctl.!default {
  type hw
  card 1
The mic and speakers start working, everything is great again!
and then i reboot and everything is back to:
pcm.!default {
  type hw
  card 1
ctl.!default {
  type hw
  card 1
and after that nothing works again (whell sound works but mic does not)
i have disabled BCM driver load in boot.conf and aplay -l and arecord -l returns only USB sound card.
so the big question of the century is how can i force the config file to stay the same as i have written? read only doesnt work it just throws error and stops loading UI, config in /etc/ also does not work. i have updated everything and upgraded also...
what now?
thanks!
  • which posts are "all of the posts here" - just for reference you understand – Jaromanda X Sep 11 '18 at 11:57
  • for example:https://raspberrypi.stackexchange.com/questions/54199/my-asoundrc-is-modified-every-reboot/88946#88946
    https://raspberrypi.stackexchange.com/questions/69821/what-modifies-my-asoundrc-file-every-boot
    https://raspberrypi.stackexchange.com/questions/58193/how-do-i-enable-usb-audio-for-gui-applications-on-raspbian-alsa-command-line-i?noredirect=1&lq=1
    sorry don't have others saved if there are any, this is not the only place I've looked :D
    – user1414449 Sep 11 '18 at 12:45
  • All good, I just wanted to see what other answers were before duplicating an answer that doesn't work :p – Jaromanda X Sep 11 '18 at 12:47
  • Any ideas? It seems that the file is rewritten once the UI is loaded. bcs i added a script to crontab to execute after reboot and it does not work. also if i set .asoundrc to read only the UI wont load... – user1414449 Sep 12 '18 at 11:32
Ok, it is weird but for now at least works... i changed boot config file back to:
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
I had it turned off previously, and now it shows that it loaded bcm as a default device, but keeps the .asoundrc file alone and sends sound through the USB also the mic works...
Im confused, but yea...
