My raspberry pi runs raspbian. The actual SD card is 32 GB. I’d like to make an image of the system installed (with my configuration and my personal files) in order to install it easily on other SD card. As the card has only 2.5GB capacity, I’d like to obtain an image of less than 4GB, so I can use smaller cards.
I have tried using win32 Disk Imager, but the image is around 30GB, so I can’t use it. I also have another computer running Linux, with no SD card reader, but with SSH access. I think I can use dd, but I don't want to obtain a big image.
Here is some information about my system on the raspberry pi:
$fdisk -l
Disk /dev/mmcblk0: 32.3 GB, 32270450688 bytes
4 heads, 16 sectors/track, 984816 cylinders, total 63028224 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x000c7b31
Device Boot Start End Blocks Id System
/dev/mmcblk0p1 8192 122879 57344 c W95 FAT32 (LBA)
/dev/mmcblk0p2 122880 63028223 31452672 83 Linux
$df -h
Sys. fich. Taille Util. Dispo Uti% Monté sur
rootfs 30G 2,1G 27G 8% /
/dev/root 30G 2,1G 27G 8% /
devtmpfs 212M 0 212M 0% /dev
tmpfs 44M 256K 44M 1% /run
tmpfs 5,0M 0 5,0M 0% /run/lock
tmpfs 88M 0 88M 0% /run/shm
/dev/mmcblk0p1 56M 22M 35M 40% /boot
