I installed OpenMediaVault on my Raspberry Pi and connected a USB 3.0 LAN adapter to the Raspberry where a LAN cable is connected. I can access the hard drive, which is also connected to the Raspberry, and OMV remotely, so the LAN adapter works.
I have defined the following network interface (eth0 is the build-in lan and eth1 is the lan adapter).
# The loopback network interface
auto lo
iface lo inet loopback
# eth0 network interface
auto eth0
allow-hotplug eth0
iface eth0 inet dhcp
iface eth0 inet6 manual
pre-down ip -6 addr flush dev $IFACE
# eth1 network interface
auto eth1
iface eth1 inet static
address 192.168.0.114
netmask 255.255.255.0
network 192.168.0.0
broadcast 192.168.0.255
gateway 192.168.0.1
ifconfig Output:
eth1 Link encap:Ethernet HWaddr 00:e0:4c:68:ce:15
inet addr:192.168.0.114 Bcast:192.168.0.255 Mask:255.255.255.0
RX packets:2743 errors:0 dropped:0 overruns:0 frame:0
TX packets:2559 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:283457 (276.8 KiB) TX bytes:5385381 (5.1 MiB)
route output:
Kernel IP routing table
default 192.168.0.1 0.0.0.0 UG 0 0 0 eth1
192.168.0.0 * 255.255.255.0 U 0 0 0 eth1
My problem is that I can't access websites outside my own network. For example the command
ping -c 4 google.com
returns
ping: unknown host google.com
So the command
sudo apt-get update
does not work either.
What am I doing wrong here?
cat /etc/resolv.conf
... There are numerous methods of assigning namesevers. I'm unfamiliar with OMV's default networking behavior. However, from the image file it looks like they may be using network manager. – RubberStamp Sep 05 '18 at 22:29ping raspberrypi.local
should respond with the unit's IPv4 address. The underlying default networking is performed via Network Manager... there's a command line interfacenmcli
and here's how to setup a static address using nmcli – RubberStamp Sep 06 '18 at 00:36
