You can make the Raspberry Pi a router that routes ethernet packages between ethernet and wifi interface. The best solution would be a bridge so the printer will get part of your network. But bridging on a wifi client connection is not supported by the on board wifi chip (1). Also using network address translation (NAT) with the printer on the RasPi is not an option because other devices want to connect to the printer and not the other way. But it is the nature of NAT that it only works in on direction, from the printer into the cloud. You cannot connect to the printer with NAT. That is the same reason why you cannot connect to computer on your local network from the internet. Your internet router also uses NAT.
I will show you how you can make the RasPi a router. I will use systemd-networkd for reasons. For routing we need two subnets. For my example I assume your wifi network has the subnet 192.168.50.0/24 and the subnet the printer is using is 192.168.1.0/24. The printer accepts an ip address from a DHCP server.
Tested with
Raspberry Pi OS (32-bit) Lite 2020-08-20 on a Raspberry Pi 4B updated at 2020-09-18.
Updates done with sudo apt update && sudo apt full-upgrade && sudo reboot.
Here you can find the last tested revision for previous Raspbian versions.
For reference I use Raspbian Stretch Lite 2018-06-27 updated with sudo apt update && sudo apt full-upgrade && sudo reboot.
Setup systemd-networkd
Just follow to Use systemd-networkd for general networking. You can use section "♦ Quick Step". Then come back here.
Setup wifi client connection
Setup wpa_supplicant with this file and your settings for country=, ssid=, psk= and enable it. You can just copy and paste this in one block to your command line beginning with cat and including EOF (delimiter EOF will not get part of the file):
root@raspberrypi:~ $ sudo -Es # if not already done
root@raspberrypi:~ # cat >/etc/wpa_supplicant/wpa_supplicant-wlan0.conf <<EOF
update_config=1
country=DE
network={
ssid="wlan@hoeft-online.de"
psk="verySecretPwassword"
EOF
root@raspberrypi:~ # chmod 600 /etc/wpa_supplicant/wpa_supplicant-wlan0.conf
root@raspberrypi:~ # systemctl disable wpa_supplicant.service
root@raspberrypi:~ # systemctl enable wpa_supplicant@wlan0.service
root@raspberrypi:~ # rfkill unblock wlan
Configure interfaces
Create these files for interfaces eth0 and wlan0 with your settings. For wlan0 don't use an ip address which is in the pool of the DHCP server from that subnet. You can just copy and paste this in one block to your command line beginning with cat and including EOF (delimiter EOF will not get part of the file):
root@raspberrypi:~ # cat > /etc/systemd/network/04-eth0.network <<EOF
[Match]
Name=eth0
[Network]
Address=192.168.1.1/24
DHCPServer=yes
IPForward=yes
[DHCPServer]
PoolSize=2
EOF
root@raspberrypi: ~# cat > /etc/systemd/network/08-wlan0.network <<EOF
[Match]
Name=wlan0
[Network]
Address=192.168.50.60/24
#Gateway = ip from your internet router
Gateway=192.168.50.1
DNS=84.200.69.80 1.1.1.1
EOF
reboot.
You should now be able to connect to the printer from your wifi network with ip address 192.168.1.2. This is why we define PoolSize=2 and 192.168.1.2 is the only left over ip address after the routers ip address 192.168.1.1. The only problem is that the internet router does not know where the device with ip address 192.168.1.2 is. We have to set a static route.
Set static route
This has the advantage that you can use any service the printer provided. You are not restricted to one port. But if you have no access to the internet router or cannot set a static route there then you can use port forwarding (see next section).
To get routing complete working you have to set a static route in your internet router so it can find the route to the printer. On most internet router you can set a static route but how to do that varies from model to model. It's up to you to find it out. For example your RasPi wlan0 interface has the static ip address 192.168.50.60. Then on your router the gateway (next hop) is 192.168.50.60, destination network is 192.168.1.0/24 (or 192.168.1.0 netmask 255.255.255.0).
That means for the internet router: "send all packets belonging to subnet 192.168.1.0/24 (destination network from AP) to the next router on my subnet, the RasPi 192.168.50.60 (gateway). It knows where to go on."
That's it.
Port forwarding
Thanks to @RalfFriedl for the suggestion in his answer. I will show in detail how I would it use in this setup.
To use port forwarding requires that the printer supports the forwared port. We use port 9100 for raw printing. You can check it with nmap 192.168.1.2 on the RasPi. You must get at least the open port:
9100/tcp open jetdirect
This is almost suported by all printer and mostly named jetdirect. For example you can select this connection on the unix printing system CUPS with AppSocket/HP JetDirect when you install the printer driver on a computer and set it for this example to:
socket://192.168.50.60:9100
On MS Windows machines it should go similar but I'm not familiar with Windows. Look where and how to set connections to network printer in the printer driver with jetdirect (I hope) to printer 192.168.50.60 and port 9100.
There is a unit to start and stop wpa_supplicant for the wifi connection. We simply add to it the iptables rule so it will be set and deleted with the wifi connection. Create a drop in file (3):
rpi ~$ sudo systemctl edit wpa_supplicant@wlan0.service
[Service]
ExecStartPost=/sbin/iptables -t nat -A PREROUTING -i wlan0 -p tcp --dport 9100 -j DNAT --to-destination 192.168.1.2
ExecStopPost=/sbin/iptables -t nat -D PREROUTING -i wlan0 -p tcp --dport 9100 -j DNAT --to-destination 192.168.1.2
Check with
rpi ~$ systemctl cat wpa_supplicant@wlan0.service
Restart the service and check if port forwarding is set:
rpi ~$ sudo systemctl daemon-reload
rpi ~$ sudo systemctl restart wpa_supplicant@wlan0.service
rpi ~$ sudo iptables -v -t nat --list
That's it.
**refefences:**
[1] Raspberry Pi WiFi to Ethernet Bridge for a server?
[2] Howto migrate from networking to systemd-networkd with dynamic failover
[3] man systemd.unit - overriding vendor settings
