I have a little problem with grounding.
I realized a circuit which is controlled by the GPIO-Pins of the Raspberry. The function of my circuit is irrelevant. You just have to know that I need the 3.3 V and 5 V from the Pins for controlling some IC's. My Output needs 500mA (USB) so I need an external supply. I get this from the USB-Port of my PC.
When I connect 5V, 3.3V, GND from the Raspberry and 5V, GND from USB-Port it doesn't work. The Raspberry crashes. When I disconnect one Ground everything works fine.
I measure the two Grounds and they have a difference of 0.2 V to each other.
What should I do? Can I just disconnect the GND of the GPIO-Pins or can the Raspberry get damaged of it? What is the reason for such a different Ground?
EDIT: A little illustration:
http://www.imgbox.de/users/public/images/KOtsjirqBh.png
The circuit is a sort of USB-Switch. With the GPIO-Pins you can choose which Device should work. So the MUX's are controlled by GPIO-Pins and powered by GPIO-Pin 1 and 2. USB out needs the 5V/500mA of the USB-Host. The Pins are protected with http://www.thebox.myzen.co.uk/Raspberry/Breakout.html
Do you need further information?
floating ground. You should always connect the two grounds together, to prevent problems and possible damage. That is, only the ground. So don't go and also connect the 5V lines :-) – Gerben Aug 06 '13 at 15:47
