I was tring to install PocketVj using this guide from the Github page.
I installed all the dependencies using sudo apt-get install...
with no problems. Followed by sudo pip install --upgrade pip
again no problems.
Sudo pip install pjlink and sudo pip install python-osc
also worked without a problem. The problem I'm facing right now is svgtools. Here are the logs of my first attempt:
My little understanding told me that I had to install the latest version of Cython. I did that with
Sudo pip install Cython
and no problems.
However now I'm getting different problems when trying to install Svgtools.
From that output I get that SciPy is missing and the wrong version of numpy installed.
So I tried to install SciPy with sudo pip install SciPy
and only get:
pi@raspberrypi:~ $ sudo pip install SciPy
Collecting SciPy
Using cached https://files.pythonhosted.org/packages/07/76/7e844757b9f3bf5ab9f951ccd3e4a8eed91ab8720b0aac8c2adcc2fdae9f/scipy-1.1.0.tar.gz
Building wheels for collected packages: SciPy
Running setup.py bdist_wheel for SciPy ... error
Complete output from command /usr/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-ev3H7e/SciPy/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/pip-wheel-YAq9vb --python-tag cp27:
/usr/lib/python2.7/distutils/dist.py:267: UserWarning: Unknown distribution option: 'python_requires'
warnings.warn(msg)
lapack_opt_info:
openblas_info:
libraries not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/arm-linux-gnueabihf']
NOT AVAILABLE
lapack_mkl_info:
mkl_info:
libraries mkl,vml,guide not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/arm-linux-gnueabihf']
NOT AVAILABLE
NOT AVAILABLE
atlas_threads_info:
Setting PTATLAS=ATLAS
libraries ptf77blas,ptcblas,atlas not found in /usr/local/lib
libraries lapack_atlas not found in /usr/local/lib
libraries ptf77blas,ptcblas,atlas not found in /usr/lib
libraries lapack_atlas not found in /usr/lib
libraries ptf77blas,ptcblas,atlas not found in /usr/lib/arm-linux-gnueabihf
libraries lapack_atlas not found in /usr/lib/arm-linux-gnueabihf
numpy.distutils.system_info.atlas_threads_info
NOT AVAILABLE
atlas_info:
libraries f77blas,cblas,atlas not found in /usr/local/lib
libraries f77blas,cblas,atlas not found in /usr/lib
libraries f77blas,cblas,atlas not found in /usr/lib/arm-linux-gnueabihf
numpy.distutils.system_info.atlas_info
NOT AVAILABLE
/usr/lib/python2.7/dist-packages/numpy/distutils/system_info.py:1427: UserWarning:
Atlas (http://math-atlas.sourceforge.net/) libraries not found.
Directories to search for the libraries can be specified in the
numpy/distutils/site.cfg file (section [atlas]) or by setting
the ATLAS environment variable.
warnings.warn(AtlasNotFoundError.__doc__)
lapack_info:
libraries lapack not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/arm-linux-gnueabihf']
NOT AVAILABLE
/usr/lib/python2.7/dist-packages/numpy/distutils/system_info.py:1438: UserWarning:
Lapack (http://www.netlib.org/lapack/) libraries not found.
numpy/distutils/site.cfg file (section [lapack]) or by setting
the LAPACK environment variable.
warnings.warn(LapackNotFoundError.__doc__)
lapack_src_info:
NOT AVAILABLE
/usr/lib/python2.7/dist-packages/numpy/distutils/system_info.py:1441: UserWarning:
Lapack (http://www.netlib.org/lapack/) sources not found.
Directories to search for the sources can be specified in the
numpy/distutils/site.cfg file (section [lapack_src]) or by setting
the LAPACK_SRC environment variable.
warnings.warn(LapackSrcNotFoundError.__doc__)
NOT AVAILABLE
Running from scipy source directory.
File "<string>", line 1, in <module>
File "/tmp/pip-install-ev3H7e/SciPy/setup.py", line 474, in <module>
setup_package()
File "/tmp/pip-install-ev3H7e/SciPy/setup.py", line 470, in setup_package
setup(**metadata)
File "/usr/lib/python2.7/dist-packages/numpy/distutils/core.py", line 135, in setup
config = configuration()
File "/tmp/pip-install-ev3H7e/SciPy/setup.py", line 388, in configuration
config.add_subpackage('scipy')
File "/usr/lib/python2.7/dist-packages/numpy/distutils/misc_util.py", line 966, in add_subpackage
caller_level = 2)
File "/usr/lib/python2.7/dist-packages/numpy/distutils/misc_util.py", line 935, in get_subpackage
caller_level = caller_level + 1)
File "/usr/lib/python2.7/dist-packages/numpy/distutils/misc_util.py", line 872, in _get_configuration_from_setup_py
config = setup_module.configuration(*args)
File "scipy/setup.py", line 15, in configuration
config.add_subpackage('linalg')
caller_level = 2)
File "scipy/linalg/setup.py", line 19, in configuration
raise NotFoundError('no lapack/blas resources found')
numpy.distutils.system_info.NotFoundError: no lapack/blas resources found
Failed building wheel for SciPy
Running setup.py clean for SciPy
Complete output from command /usr/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-ev3H7e/SciPy/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" clean --all:
`setup.py clean` is not supported, use one of the following instead:
- `git clean -xdf` (cleans all files)
- `git clean -Xdf` (cleans all versioned files, doesn't touch
files that aren't checked into the git repo)
Add `--force` to your command to use it anyway if you must (unsupported).
Failed cleaning build dir for SciPy
Failed to build SciPy
Installing collected packages: SciPy
Running setup.py install for SciPy ... error
Complete output from command /usr/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-ev3H7e/SciPy/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-x1rbgQ/install-record.txt --single-version-externally-managed --compile:
Note: if you need reliable uninstall behavior, then install
with pip instead of using `setup.py install`:
- `pip install .` (from a git repo or downloaded source
release)
- `pip install scipy` (last SciPy release on PyPI)
warnings.warn(msg)
lapack_opt_info:
openblas_info:
NOT AVAILABLE
lapack_mkl_info:
mkl_info:
NOT AVAILABLE
NOT AVAILABLE
atlas_threads_info:
NOT AVAILABLE
atlas_info:
NOT AVAILABLE
lapack_info:
NOT AVAILABLE
lapack_src_info:
NOT AVAILABLE
NOT AVAILABLE
setup_package()
setup(**metadata)
caller_level = 2)
caller_level = 2)
Command "/usr/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-ev3H7e/SciPy/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-x1rbgQ/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in /tmp/pip-install-ev3H7e/SciPy/
Does anyone know how I can solve this problem and sucesfull install SciPy in order to get Svgtools up and running?
