the ntp string isn't found in syslog. It's definitely not running. But when it has internet access, it has the right time. What's the mechanism?
This is on Raspbian Stretch minimal install.
In Stretch the synchronisation is done using a systemd service (systemd-timesyncd.service) and a new program (systemd-timesyncd)
For time status information use timedatectl
For status information about the timesync service use
sudo systemctl status systemd-timesyncd
You will probably see the time has been updated at some point
More information is available with
man systemd-timesyncd.service
    I'm posting an answer to augment @Dirk's answer, not to take exception. I believe @Dirk's answer is completely accurate, but it did pique my curiosity for details. I'm posting some of those details here as they may be relevant for some (including the OP).
As @Dirk mentioned, the ntp client was replaced with systemd-timesyncd beginning with the stretch distribution. It seems there were two motivations for this replacement:
ntp was not an example of "good software"All well and good, yet according to the documentation, there were some tradeoffs made:
The systemd-timesyncd service specifically implements only SNTP. This minimalistic service will set the system clock for large offsets or slowly adjust it for smaller deltas. More complex use cases are not covered by systemd-timesyncd.
SNTP is the Simple Network Time Protocol defined by RFC2030, which says in part:
SNTP can be used when the ultimate performance of the full NTP implementation described in RFC-1305 is not needed or justified.
A discussion of the diffs between NTP and SNTP can be found here, which quotes another passage from RFC-2030:
SNTP servers should operate only at the root (stratum 1) of the subnet and then only in configurations where no other source of synchronization other than a reliable radio or modem time service is available.
This should NOT be taken as a suggestion that the systemd-timesyncd timekeeping function in RPi is unsuitable. It is after all, a "hobbyist computer"... but then so were Macs and PCs when they first arrived. And so there may be "serious" applications for Raspberry Pis that demand NTP over SNTP, or there may be other applications wherein the user wants or needs the ability to, for example, exercise control of the timekeeping function with a program or script[1, 2]. In these cases, systemd-timesyncd may fall short.
If you fall into this category, and feel systemd-timesyncd doesn't meet your needs, you have at least three options:
install ntp; the client used on RPi prior to the stretch release, and maintained by the Network Time Protocol project
install openntpd; a client developed as part of the OpenBSD project
ArchLinux has documentation on ntp, openntpd and chrony that may help you decide which best suits your needs. You may also wish to review the docs for timedatectl available on ArchLinux before you make this change. All three packages are available for RPi, can be installed with the usual sudo apt-get install X incantations.
If you elect to install one of these NTP implementations, you could disable systemd-timesyncd as follows:
$ timedatectl set-ntp false
However: As my colleague @Ingo has pointed out, this is not necessary since systemd-timesyncd checks for the presence of other NTP daemons, and will adjust its behavior accordingly; see systemctl cat systemd-timesyncd.
Debian (and therefore RPi OS) have changed the way that conflicts in timekeeping daemons are addressed. They are now addressed at the apt package level. IOW, if you are running systemd-timesyncd, and you try to install another timekeeping daemon (e.g. chrony), apt will only permit that if you first allow it to un-install systemd-timesyncd. REFS: 1, 2, 3
    systemd-timesyncd. It will check if there is another NTP daemon installed. Check with `systemctl cat systemd-timesyncd´, bottom lines.
        – Ingo
                Aug 10 '18 at 10:02
    systemctl cat systemd-timesyncd is an odd one! It lists 48 lines & stops... I've not found any way to get the rest of the file, and man systemctl is silent on that topic. As an aside, it seems that systemctl is in "takeovertheworld" mode  :)
        – Seamus
                Aug 10 '18 at 12:48
    systemd-timesyncd has 52 lines including copyright disclaimer and with systemctl cat it is opened in a pager (less) so you should be able to easily scroll down. And yes, systemd has already taken over the world. Everything from "the old stuff" is only emulated by systemd, even fstab (man systemd.generator).
        – Ingo
                Aug 10 '18 at 13:11
    lines 1-48 is displayed in inverse video at the bottom of my screen, then most of the "usual" keys terminate it, and take me to command prompt. However, if I resize my terminal window, the paging behavior becomes "normal". But yes, systemd is pervasive now... not sure I like that just yet, but we'll see.
        – Seamus
                Aug 10 '18 at 13:23
