i've never had this error since i bought my rpi3 last january. Any advice?
Details:
OS: Raspbian Stretch
Never edited /etc/network/interfaces as pi is attached to router via cable and had not needed to use wi-fi
journalctl -e (errors found)
vc_vhci_sm_init: failed to open VCHI service (-1)
[vc_sm_connected_init]: failed to initialize shared memory service
brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 7.11.15 Compiler: 1.24.2 ClmImport: 1.24.1 Creation: 2014-05-26 10:53:55 Inc Data: 9.10.41 Inc Compiler: 1.29.4 Inc ClmImport: 1.36.3 Creation: 2017-08-07 00:37:47
sd 0:0:0:0 [sda] No Caching mode page found
sd 0:0:0:0 [sda] Assuming drive cache: write through
dhcpcd.service: Failed at step EXEC spawning /usr/lib/dhcpcd5/dhcpcd: Exec format error
dhcpcd.service: Control process exited, code=exited status=203
Failed to start dhcpcd on all interfaces
dhcpcd.service: Unit entered failed state
dhcpcd.service: Failed with result 'exit-code'
Kurover
For those googlin' "failed to start dhcpcd on all interfaces" like myself:
  • NB: This is relevant to Raspbian Stretch; for a different release, the situation may differ.
Essentially, if your Pi has a wired DHCP connection, and you have eth0 in /etc/network/interfaces -- something like that :
# .. loopback interface ..
auto eth0
iface eth0 inet dhcp
Then it shall be enough and you can now disable dhcpcd.service :
systemctl disable dhcpcd
This shall be it -- reboot ( and don't forget to start your DCHP server, if your client is dhcp-bound ) and you shall not have this message for anymore.
Explanation: I suppose we have triggered dhcpcd.service into an enabled state, and since its Description field is "dhcpcd on all interfaces" -- it goes into the log file as "failed to start dhcpcd on all interfaces" . That's it.
  • Edit: fixed typos, thanks Ingo
ジョージ
  • 141
  • Seems you have done some typos. There is no dhcpd service you can disable. Do you mean dhcpcd? – Ingo Jan 20 '19 at 13:57
  • @Ingo : thanks, it did not occur to me it has a 'c' there. I mean, I did it just not too long ago, but nevertheless did some typing mistakes here. Thanks again ) – ジョージ Jan 20 '19 at 14:58
    Of course -- my bad. It is a client, therefore it shall go with a 'c'. – ジョージ Jan 20 '19 at 15:00
