If you do sudo iwlist wlan0 scan freq 2412 or sudo iw wlan0 scan freq 2412 you will get a full scan and not a channel scan.
I think there maybe a bug in the RPi implementation of iw.
Has anyone had success with this function on the Pi?
After working with one of the iw dev team, he shared a command option that works every time.
Adding the "flush" option works with the RPi-3b I am using.
sudo iw scann freq 2412 flush
It does not work with a Lenovo/IBM Thinkpad I have with an old 54g WiFi card in it.
It appears there maybe a caching issue for them to address on some implementations.
sudo iw dev wlan0 scan freq 2412. On my RPi 3B with Raspbian Stretch Lite 2018-06-27 it works no matter if I use flush or not. It filters networks with channel 1 (freq 2412) but not from the 5 GHz band.
– Ingo
Aug 25 '18 at 09:16
In the "sudo iw scann freq 2412 flush" answer the scan had an extra "n" in it.
The "dev" is not required.
Of course locking the scan to channel 1 does not do anything in the 5GHz band as the lowest channel in 5GHz is channel 36.
Thanks for catching it.
– padapa Sep 03 '18 at 13:25
