I have installed lighttpd on my RPI 3 :
sudo apt-get install lighttpd
I have managed to access the web server from /home/pi/www And it works, I can find my Hello World when I entered 192.168.2.31 in my URL browser.
Now I try to access my raspberry pi through mDns. In this way I have installed AVAHI :
sudo apt-get install avahi-daemon libavahi-client-dev
I have modified my hostname :
Sudo raspi-config
and then select Network option then select Hostname then I have called it raspberrypik
I have updated my reboot system :
sudo update-rc.d avahi-daemon defaults
Now I try to access my web server from my browser, from either Windows 10 where Itunes is installed and my smartphone (I shared the Hotspot of my cellphone with the RPI) by typing raspberrypik.local but nothing happen.
Some tutorials use AVAHI to get acces on the RPI through SSH. I tried to access my RPI via SSH with raspberrypik.local, but nothing...
I have tried what is indicated in this post : How to debug avahi-daemon? Hostname not coming through
But when I do
$ ls -l /etc/avahi/services/
total 4
-rw-r--r-- 1 root root 243 Aug 2 05:53 ssh.service
The folder multiple.service and udisks.service are not present, is it normal ?
When I do :
$ avahi-browse -a
-bash: avahi-browse: command not found
When I ping I get :
~ $ ping -c 4 raspberrypik
PING raspberrypik (127.0.1.1) 56(84) bytes of data.
64 bytes from raspberrypik (127.0.1.1): icmp_seq=1 ttl=64 time=0.108 ms
64 bytes from raspberrypik (127.0.1.1): icmp_seq=2 ttl=64 time=0.076 ms
64 bytes from raspberrypik (127.0.1.1): icmp_seq=3 ttl=64 time=0.098 ms
64 bytes from raspberrypik (127.0.1.1): icmp_seq=4 ttl=64 time=0.104 ms
--- raspberrypik ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3098ms
rtt min/avg/max/mdev = 0.076/0.096/0.108/0.015 ms
Now if I follow the post I get :
~ $ avahi-resolve
-bash: avahi-resolve: command not found
And finally :
~ $ tcpdump -i wlan0 port 5353 or igmp -w /tmp/mdns.pcap
-bash: tcpdump: command not found
Ok I do things wrong, but where ??
Thank you for your help
avahi-toolsyou have installed now you can browse and discover services. Maybe you have to use them withsudo. To use tcpdump you have to install it withsudo apt install tcpdumpand has to run withsudo. If avahi has configured a link-local address then you address your RasPi withraspberrypik.local. Look withip addrwhat ip address your RasPi has. – Ingo Aug 07 '18 at 10:25127.0.1.1defined in/etc/hosts. – Ingo Aug 07 '18 at 10:27ip addrand it displays the WANL0 with the IP address attributed by the DHCP of the router. I have watched the content of the folder/etc/hostsand it contains this : `27.0.0.1 localhost ::1 localhost ip6-localhost ip6-loopback ff02::1 ip6-allnodes ff02::2 ip6-allrouters127.0.1.1 raspberrypik ` . Eventually, I ping raspberrypik (and raspberrypik.local) from windows connected to the same network and nothing ....
– FrancNovation Aug 07 '18 at 14:48
