I followed https://hacks.mozilla.org/2017/02/headless-raspberry-pi-configuration-over-bluetooth/
I see nothing on the bluetooth devices in my cellphone or computer. Here's the output of my raspberry pi:
pi@raspberrypi:~ $ sudo service bluetooth status
● bluetooth.service - Bluetooth service
   Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
   Active: active (running) since Wed 2018-06-27 01:27:58 UTC; 4min 10s ago
     Docs: man:bluetoothd(8)
 Main PID: 443 (bluetoothd)
   Status: "Running"
   CGroup: /system.slice/bluetooth.service
           └─443 /usr/lib/bluetooth/bluetoothd
Jun 27 01:27:58 raspberrypi systemd[1]: Starting Bluetooth service... Jun 27 01:27:58 raspberrypi bluetoothd[443]: Bluetooth daemon 5.43 Jun 27 01:27:58 raspberrypi systemd[1]: Started Bluetooth service. Jun 27 01:27:58 raspberrypi bluetoothd[443]: Starting SDP server Jun 27 01:27:59 raspberrypi bluetoothd[443]: Bluetooth management interface 1.14 initialized Jun 27 01:27:59 raspberrypi bluetoothd[443]: Failed to obtain handles for "Service Changed" characteristic Jun 27 01:27:59 raspberrypi bluetoothd[443]: Sap driver initialization failed. Jun 27 01:27:59 raspberrypi bluetoothd[443]: sap-server: Operation not permitted (1)
I also tried running rfcomm on the terminal but it returns immediately.
I also tried:
pi@raspberrypi:~ $ /usr/bin/rfcomm watch hci0 1 getty rfcomm0 115200 vt100 -a pi
Waiting for connection on channel 1
but I still see nothing on the bluetooth devices. I waited 10 minutes and nothing appears.
UPDATE:
I found a video which tells me to add a -C in front of the bluetooth service and also do this:
sudo bluetoothctl
power on
pairable on
discoverable on
agent on
default-agent trust
Now I can connect to the raspberry pi but it stays connected for 1 second and then disconnects
UPDATE:
I tried pairing from my PC to the raspberry, and then from the raspberyr to PC. Both ways it pairs, then the two paires devices disconnect. It only connect for 2 seconds.
Guerlando OCs
  • I have this exact same problem. I followed https://hacks.mozilla.org/2017/02/headless-raspberry-pi-configuration-over-bluetooth/ and I cannot stay connected for more than a second or two. Were you able to figure it out? – Deepak Mittal Oct 29 '18 at 19:06
  • @DeepakMittal nope, I never tried it anymore. If you figure it out, please post here to help me and others – Guerlando OCs Oct 29 '18 at 19:50
  • I've seen you guys and another person complain about only being able to connect for a few seconds. – YetAnotherRandomUser Jan 27 '19 at 03:31
0 Answers0
