My /etc/dhcpcd.conf file is configured so that if I manually run this wpa_supplicant command from the terminal:
wpa_supplicant -B -D nl80211 -P /var/run/wpaSupplicantPid.pid -i wlan0 -c /etc/wpa_supplicant/wpa_supplicant.conf
it fetches my static IP address and settings and I get connectivity. However, this is not automatic, and the connected state does not survive a reboot and I need to run this command again to get connectivity. If it survived the reboot, I wouldn't mind running the command once, so I presume this could be solved by altering the startup script, but that is beyond my scope of knowledge. I've also seen all the related questions about calling wpa_supplicant from the dhcpcd somehow using "hooks" (in quotes because I'm new to the term), but I have not been able to figure out how to configure a hook script to run the proper wpa_supplicant command. On startup, a wpa_supplicant command does execute, but it does not result in connectivity and I don't know where to find/alter it. Running ps -aux | grep supplicant with connectivity yields:
root 2364 0.0 0.0 44892 3100 ? Ss 10:46 0:00 wpa_supplicant -B -D nl80211 -P /var/run/wpaSupplicantPid.pid -i wlan0 -c /etc/wpa_supplicant/wpa_supplicant.conf
root 2843 0.0 0.0 21536 1056 pts/0 S+ 11:17 0:00 grep --color=auto supplicant
and after reboot ps -aux | grep supplicant yields the following and there is no connectivity:
root 834 0.0 0.0 44752 2792 ? Ss 11:19 0:00 /sbin/wpa_supplicant -u -s -O /run/wpa_supplicant
root 1972 0.0 0.0 21536 1032 pts/0 S+ 11:20 0:00 grep --color=auto supplicant
Here is my /etc/dhcpcd.conf file:
# Inform the DHCP server of our hostname for DDNS.
hostname
# Use the hardware address of the interface for the Client ID.
#clientid
# or
# Use the same DUID + IAID as set in DHCPv6 for DHCPv4 ClientID as per RFC4361.
# Some non-RFC compliant DHCP servers do not reply with this set.
# In this case, comment out duid and enable clientid above.
duid
# Persist interface configuration when dhcpcd exits.
persistent
# Rapid commit support.
# Safe to enable by default because it requires the equivalent option set
# on the server to actually work.
option rapid_commit
# A list of options to request from the DHCP server.
# Most distributions have NTP support.
option ntp_servers
# Respect the network MTU. This is applied to DHCP routes.
option interface_mtu
# A ServerID is required by RFC2131.
# Generate Stable Private IPv6 Addresses instead of hardware based ones
slaac private
noarp
denyinterfaces eth0
profile 10.1.3.1
interface wlan0
static ip_address=10.1.3.252/24
static routers=10.1.3.1
static domain_name_servers=8.8.8.8 8.8.4.4
wpa_supplicant_start()
env wpa_supplicant_conf=/etc/wpa_supplicant/wpa_supplicant.conf
My /etc/wpa_supplicant/wpa_supplicant.conf file contains:
network={
ssid="myssid"
#psk="mypassword"
psk=dfda8d552e6e45de5d3fffcb4dcfa8383jdhst3674k9555507ece98c7952b7f6
country=US
ctrl_interface=/var/run/wpa_supplicant
update_config=1
